12-25-2014 12:43 PM - edited 03-18-2019 11:26 AM
We have a requirement that one of our client require to configure one fixed number like 6666 for one international Help-desk number. In CUCM, they want to configure this number. Second thing they are acquiring, is it possible that when any person dial 6666 call goes out respectively from their local router. Not from their HO router.
Humza Khan
Solved! Go to Solution.
12-25-2014 02:19 PM
you can simply configure Translation pattern to translate the called number.
you can route the call from any gateway you want
Anas
don't forget to rate the helpful posts
12-25-2014 09:25 PM
A TP and local route groups are all you need for what you're asking
12-25-2014 02:19 PM
Anas
12-26-2014 05:16 AM
I tried with translation pattern, call is routing from HO router, not from remote side router. I assigned css which contains outbound calls partitions of all remote & HO sides. But all in vain.
Any Suggestions.
Humza Khan
12-26-2014 08:17 AM
All what you need and translation pattern and calling search space. It is normal call routing.
Please clarify your setup and design aligned with dial plan
Anas
Don't forget to rate the helpful posts
12-25-2014 09:25 PM
