05-09-2017 02:43 PM - edited 03-17-2019 10:17 AM
Hi.. I have Cisco 2911 router with 4 E1s activated on it. And 1xPVDM3-16 & 1xPVDM3-128. Every alternative day, all the E1's start flapping. After a reload of router, the E1s become stable for few days and then again start to flap.
IOS version : c2900-universalk9-mz.SPA.155-3.M5.bin
Below is the inventory on the router
NAME: "VWIC3-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 0", DESCR: "VWIC3-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC3-2MFT-T1/E1 , VID: V01 , SN:
NAME: "VWIC3-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 1", DESCR: "VWIC3-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
NAME: "PVDM3 DSP DIMM with 16 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 16 Channels"
PID: PVDM3-16 , VID: V01 , SN:
NAME: "PVDM3 DSP DIMM with 128 Channels on Slot 0 SubSlot 5", DESCR: "PVDM3 DSP DIMM with 128 Channels"
PID: PVDM3-128 , VID: V01 , SN:
Noticed one thing after the reload that there is one DSP error.%FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally.
Upon checking show voice dsp group all i can see "2 DSP resource allocation failure"
Below is the output for it:
sh voice dsp group al
DSP groups on slot 0:
dsp 1:
State: UP, firmware: 40.2.11
Max signal/voice channel: 16/16
Max credits: 240, Voice credits: 240, Video credits: 0
num_of_sig_chnls_allocated: 16
Transcoding channels allocated: 0
Group: FLEX_GROUP_VOICE, complexity: FLEX
Shared credits: 240, reserved credits: 0
Signaling channels allocated: 16
Voice channels allocated: 0
Credits used (rounded-up): 0
Slot: 0
Device idx: 0
PVDM Slot: 0
Dsp Type: SP2600
dsp 7:
Max signal/voice channel: 43/43
Max credits: 645, Voice credits: 645, Video credits: 0
num_of_sig_chnls_allocated: 43
Shared credits: 645, reserved credits: 0
Signaling channels allocated: 43
Slot: 0
Device idx: 0
PVDM Slot: 1
Dsp Type: SP2600
dsp 8:
Slot: 0
Device idx: 0
PVDM Slot: 1
Dsp Type: SP2600
dsp 9:
Max signal/voice channel: 42/43
num_of_sig_chnls_allocated: 18
Signaling channels allocated: 18
Slot: 0
Device idx: 0
PVDM Slot: 1
Dsp Type: SP2600
DSP groups on slot 1:
This command is not applicable to slot 1
05-09-2017 07:01 PM
Raise a TAC case
