For Incoming PSTN calls, the called party hears ringback
We have two incoming dial-peers pointing to two subscribers on a cisco SIP cube.
Calls hitting first dial-peer does not have any issue. For calls hitting the other dial-peer pointing to secondary subscriber, called party hears ring-back even after call is answered on jabber for incoming PSTN calls.
Looks like an issue with SDP negotiation between cube and subscriber. In the attached image, First call is successful where as the second one is having the issue. Middle line - Cube, Last two lines are subscribers
Sadav Ansari
Rising star
Rising star
Please share the debug for both working and non working call.
Debug ccsip messages
debug voice ccapi inout
Please rate if its “Helpful”. If this answered your question pls click “Accept as Solution”
Recognize Your Peers
