Forced Authentication code in CME version 8.8
Avinash Kumar G
I have a client who wanted FAC to be enabled in their CME router.They already have some calling restrictions enabled.FAC to be enabled to those users  who doesn't posses any calling restriction.Can anybody help me out in this.
|client requirement:
For long distance calls after dialing 9 ,the user prompt must be heard for forced authentication code.
For local calls after dialing 9, the FAC should not ask.
Total they have around 60 phones.
Only 10 phones they want to enable FAC.
Rest of the phones already have some calling restriction enabled through translation rule, that should not be altered.
Anyone have a running configuration for this.I have tried the configuration that i got from CME guide,but it didn't work.
If you create an lpcor resource group, how to remove it.
4 Accepted Solutions
Hi Avinash,
Attach your CME router config and let us know where you falling to achieve FAC.
CME 8.8 support FAC.
Manish
Hi Avinash,
Check these threads
https://supportforums.cisco.com/thread/2089663
https://supportforums.cisco.com/thread/2074398
And also a clip posted on CSC for FAC.
Please do go through the steps. Hope this helps.
FAC (Forced Authorization Code) – LPCOR for SIP & SCCP Phones
Before  Defining LPCOR, please keep in mind that; Enable LPCOR functionality  and define a policy for each resource group that requires call  restrictions. You can define one LPCOR policy for each resource group. Do not create a LPCOR policy for resource groups that do not require call restrictions. Maximum of the procedures are same as configuring dial-peer COR list.
voice lpcor enable
// Enabling the lpcor functionality on the Cisco Unified CME router.
voice lpcor custom
// Defines the name and number of LPCOR resource groups on the Cisco Unified CME router.
group 10 ild
// Adds an LPCOR resource group to the custom resource list.
number—Group number of the LPCOR entry. Range: 1 to 64.
lpcor-group—String that identifies the LPCOR resource group.
voice lpcor policy ild
// Creates a LPCOR policy for a resource group.
lpcor-group—Name of the resource group that you defined above (in our example ild).
service fac
// Enable FAC Service for a routing endpoint defined in a LPCOR group policy
accept ild fac
// fac—Valid Forced Authorization Code that the caller needs to enter before the call is routed to its destination
There is no big point in putting the FAC command after accept ild because, even if you do not put the fac, it will still ask you for an  authorization code. Reason, you will know, when you read the  configuration below.
If you create any other group say Ex. group local,  in the same voice lpcor custom and do not enter it in the lpcor policy  ild, it will get rejected (even before the process to ask for a code  & pin). Calls will not even pass through the trunk.
The  steps for accept and reject is configured, when you have more than 2/3  groups & 3/4 different gateways / trunks and you do not want anybody  else (apart from the ones you have configured to accept) to pass  through a specific trunk.
* Create only those groups that you need to be asked for an authorization code. Don’t get confused.
Just look at the Example of show voice lpcor policy below. The ones that the output shows as reject, will not be allowed to  make calls from that trunk which is allowed for a particular group. It  means, that only groups Manger & PSTNTrunk will be allowed to make  calls (by putting an id & pin). Local Users, Remote Users, & IP  Trunk users will not be allowed to make calls. Their calls will be  rejected & they will get a fast busy tone.
Router# show voice lpcor policy
voice lpcor policy PSTNTrunk (group 13):
service fac is enabled
( accept ) Manager (group 10)
( reject ) LocalUser (group 11)
( reject ) RemoteUser (group 12)
( accept ) PSTNTrunk (group 13)
( reject ) IPTrunk (group 14)
Defining Parameters for Authorization Package:
enable
configure terminal
application
// Enters the application configuration mode.
package auth
// Enters package authorization configuration mode.
  param passwd-prompt flash:enter_pin.au
// Allows you to enter the password parameters required for package authorization for FAC authentication
    passwd-prompt filename — Plays an audio prompt requesting the caller to enter a valid password (in digits) for authorization
  param max-retries 0
// Specifies number of attempts to re-enter an account or a password – default value 0
  param user-prompt flash:enter_account.au
// Allows you to enter the user name parameters required for package authorization for FAC authentication.
    user-prompt filename — Plays an audio prompt requesting the caller to enter a valid username (in digits) for authorization
  param term-digit #
//  Specifies digit for terminating an account or a password digit  collection. You have to press # after you have input your id and then  put your pin and press #. # is the terminator to make the CME understand  that you have finished entering your ID / PIN.
  param passwd 12345
// Character string that defines a predefined password for authorization. Note: Password digits collection is optional if password digits are predefined in the param passwd command.
  param abort-digit *
//Specifies the digit for aborting username or password digit input. Default value is *.
  param max-digits 32
//Maximum number of digits in a username or password. Range of valid value: 1 - 32. Default value is 32.
You have to configure the aaa to force the FAC for Code and PIN:
gw-accounting aaa
aaa new-model
aaa authentication login default local
aaa authentication login h323 local
aaa authorization exec h323 local
aaa authorization network h323 local
aaa session-id common
Define the Username & Password:
username 786 password 0 54321
username 678 password 0 12345
Configuring the LPCOR with Ephone-DNs:
ephone-dn 1 dual-line
number 1002
label Ganesh
ephone 1
lpcor type local
// Sets the LPCOR type for an IP phone.
local—IP phone always registers to Cisco Unified CME through the LAN.
remote—IP phone always registers to Cisco Unified CME through the WAN.
lpcor incoming ild
// Associates a LPCOR resource-group policy with an incoming call
Note: Do not use different lpcor group policies for a shared ephone-dn.
device-security-mode none
mac-address 0005.9A3C.7A00
type CIPC
button 1:1
Same is used for SIP Phones:
voice register pool 2
lpcor type remote
lpcor incoming ild
id mac 0030.94C2.9A55
type 7960
number 1 dn 2
dtmf-relay rtp-nte sip-notify
Note: If you do not put rtp-nte, it will skip the process of asking for the Authorization Code and you will not be able to make any calls
Configuring the LPCORs with the ISDN (BRI / PRI) Ports:
The Example Provided below is my BRI Configuration:
This Voice Port 0/1/0 – is used for Local Calls only without any authorization codes
voice-port 0/1/0
disc_pi_off
input gain -6
echo-cancel mode 2
mwi
no vad
compand-type a-law
cptone FR
timeouts call-disconnect 1
connection plar 1000
threshold noise -60
bearer-cap Speech
This Voice Port 0/1/1 – is used for only International Calls with authorization codes:
voice-port 0/1/1
lpcor outgoing ild – (Defined the LPcor outgoing in voice-port 0/1/1 – dedicated for ILD – Long Distance)
disc_pi_off
input gain -6
echo-cancel mode 2
mwi
no vad
compand-type a-law
cptone FR
threshold noise -60
bearer-cap Speech
Note: The  biggest problem in an Environment / Scenario where we use lpcor is that  we have to block dedicatedly one trunk / BRI / PRI port specifically  only for ILDs (Calls with Authorization) and the 2nd line/trunk for Calls that don't need Authorization
Complete Configuration of LPcor in Short - Example:
voice lpcor enable
voice lpcor custom
group 10 ild
service fac
accept ild fac
aaa new-model
application
package auth
  param max-retries 0
  param term-digit #
  param passwd 12345
  param abort-digit *
  param max-digits 32
number 1002
label Ganesh
ephone 1
lpcor type local
lpcor incoming ild
type CIPC
button 1:1
voice register dn 2
number 4001
name cme-sip-2
label 4001
lpcor type remote
lpcor incoming ild
number 1 dn 2
voice-class codec 1
voice-port 0/1/0
disc_pi_off
input gain -6
echo-cancel mode 2
mwi
no vad
compand-type a-law
cptone FR
threshold noise -60
bearer-cap Speech
voice-port 0/1/1
lpcor outgoing ild
disc_pi_off
input gain -6
echo-cancel mode 2
mwi
no vad
compand-type a-law
cptone FR
threshold noise -60
bearer-cap Speech
Apart from these, you need to configure dial-peer cors, dial-plan pattern, translation pattern and other configuration as usual.
Note: There are lots of issues, mistakes and confusion in the Explanation  provided in Cisco’s CME Administration Guide for LPCOR – FAC. Some of  them are mismatched / wrongly given both in Detailed Steps as well as  the Example provided for FAC (Forced Authorization Code)
Issue – 1:
There is lot of confusion and mistake in deciding which .au file to be taken for prompting the password and account-id.
There are two steps for this:
1.        The first method, is it asks for an account id and the then it asks for  the pin number, that should match with the associated username.
a.       For this method, you may / may not put the param password #### command. It doesn’t matter.
b.      The au files I have selected for this method is: enter_account.au for ID & enter_pin.au for the PIN. This works perfectly fine.
2.       The 2nd method – if you have put the param passwd #### command,
a.       Use the userprompt filename as enter_account.au
b.      For the param passwd-prompt, use en_bacd_enter_dest.au file.
Once  you enter the destination number, your call will get connected, as the  password has already been forced into the configuration.
The 2nd Method will work, better for intercom calls (between sites) or Local /  STD calls. i.e;  when you enter the dial-out prefix (0 / 9) + Local Code  & press #  It  will ask for your Account ID. Enter the Account ID and press #. Then  Enter the Destination Number you wish to reach. It will put your call  through.
Logically this is correct; but technically wrong; because according to the FAC Configuration / System,
1.        It requires & asks for an ID & PIN. You cannot configure just a  Username (account name) or a Password alone. It has to be bundled  together. Every ID & its respective PIN is entered in Global  Configuration Mode. Ex. Router(config)# username 12345 password 12345
2.        It asks for ID & PIN only after you have finished dialing. Ex. 0 +  International Code + Number. Then it asks you to enter the ID and press  #. Then Pin No. and press #. Then the call gets routed to the respective  port
So Technically, the 2nd method will not work for International Numbers. What will you dial  after it asks to dial the destination code? How will the cme associate  the number dialed after putting the dial-out prefix and the number  dialed when the FAC asks to enter the Destination Code? Ex. 0 – 44 # (account id) - Destination Number? It does not work at all. Also it does not make any sense.
Issue – 2:
There are some confusion in filenames as well. Even the audio provided inside the file, against the filename does not match.
1.        en_bacd_welcome.au – does not ask you for an Account ID. It says “Thank  you for calling”. What is that supposed to mean?
2.        en_bacd_enter_dest.au – will ask you to provide the destination number  you wish to reach. Where is the ID and / or Password asked in a scenario  like this?
Issue – 3:
ephone 1
lpcor type local
The IP Phone has nothing to do with registration in this command. With the command lpcor type local, it actually searches for the authorization code locally with radius server from within the CME itself.
And Remote means it searches for the authorization code from a remote aaa server / other CME located in remote site.
I have tried to make the LPCor configuration a bit simple and easy to understand. Hope this helps.
Rate all the helpful post.
Manish
voice lpcor custom
no group number
Manish
11 Replies 11
Siva chinap
Level 5
Level 5
Need to check wether FAC will support CME or not
Its a Cisco 3925 series router. I think it supports.
Hi Sivakalam,
Thanks for the link but it won't work in this case. i want a running configuration because i don't have a 3925 ios image to run and test these commands.If some how i get an ios image i can workout this with the clients running configuration.
Hi Avinash,
Manish
Enabling FAC Service.
Router> enable
Router# configure terminal
Router(config)# voice lpcor enable
Router(config)# voice lpcor custom
Router(cfg-lpcor-custom)#group 12 Manager
Router(cfg-lpcor-policy)# accept Manager fac
Router(cfg-lpcor-policy)#service fac
exit.
Defining parameter
Router> enable
Router(config)#application
Router(config-app)#package auth
Router(config-app-param)#param user-prompt flash:enter_account.au
Router(config-app-param)#param passwd-prompt flash:enter_pin.au
Router(config-app-param)#param max-retries 0
Router(config-app-param)#param term-digit #
Router(config-app-param)#param abort-digit *
Router(config-app-param)#param max-digits 32
Router(conf-app-param)# exit
Router(config)#username 1 password 0011
Router(config)#username 1 password 0012
Router(config)#aaa new-model
Router(config)#aaa authentication login default local
Router(config)#aaa authentication login h323 local
Router(config)#aaa authorization exec h323 local
Router(config)#aaa authorization network h323 local
Router(config)#aaa session-id common
Router(config)#ephone 1
Router(config-ephone)lpcor local
Router(config-ephone)lpcor incoming manager
Upto this i did. Now where to apply the FAC. Currently they are using  PRI E1 trunk.Should i create a seperate route pattern or a seperate trunk port for fac enabled calls.
Will that user audio prompt play automatically or  whether i have to record and upload it.
Hi Avinash,
Check these threads
voice lpcor enable
voice lpcor custom
group 10 ild
service fac
accept ild fac
enable
configure terminal
application
package auth
  param max-retries 0
  param term-digit #
  param passwd 12345
  param abort-digit *
  param max-digits 32
gw-accounting aaa
aaa new-model
number 1002
label Ganesh
ephone 1
lpcor type local
lpcor incoming ild
type CIPC
button 1:1
lpcor type remote
lpcor incoming ild
type 7960
number 1 dn 2
voice-port 0/1/0
disc_pi_off
input gain -6
echo-cancel mode 2
mwi
no vad
compand-type a-law
cptone FR
threshold noise -60
bearer-cap Speech
voice-port 0/1/1
disc_pi_off
input gain -6
echo-cancel mode 2
mwi
no vad
compand-type a-law
cptone FR
threshold noise -60
bearer-cap Speech
voice lpcor enable
voice lpcor custom
group 10 ild
service fac
accept ild fac
aaa new-model
application
package auth
  param max-retries 0
  param term-digit #
  param passwd 12345
  param abort-digit *
  param max-digits 32
number 1002
label Ganesh
ephone 1
lpcor type local
lpcor incoming ild
type CIPC
button 1:1
voice register dn 2
number 4001
name cme-sip-2
label 4001
lpcor type remote
lpcor incoming ild
number 1 dn 2
voice-class codec 1
voice-port 0/1/0
disc_pi_off
input gain -6
echo-cancel mode 2
mwi
no vad
compand-type a-law
cptone FR
threshold noise -60
bearer-cap Speech
voice-port 0/1/1
lpcor outgoing ild
disc_pi_off
input gain -6
echo-cancel mode 2
mwi
no vad
compand-type a-law
cptone FR
threshold noise -60
bearer-cap Speech
Issue – 1:
Issue – 2:
Issue – 3:
ephone 1
lpcor type local
Manish
Thanks Manish, but the problem is i have to configure it according to the client requirement for that i need an ios image of 3925 series to try out these commands.For the past two days i am in search of 3900 series ios image but till now i didn't get it.Any sites where we gets this image.
Hi Manish,
Thanks for the link. How can i delete an already created LPCOR group from the router.
voice lpcor custom
no group number
Manish
