Forced Authorization Code ... no soft screen, just tone?
CHRIS HUFF
When FAC/Forced Authorization Code is enabled on a pattern, the user is prompted to submit the code with the softscreen instead of just via a tone. Is there a way to change this behavior so that it is just the tone without the screen prompt?
If it matters, most of the phones we're using are CP-7821's
Vivek Batra
AFAIK, you can not change the phone display as you want in this case.
- Vivek
