Forward calls on Cube
Joli Martinez
We have DID's coming into our Cube GW.  We would like to take one of those DID's and forward it back out to our SIP provider for termination.  We dont want to change the calling party number.
ex.
calling (000-000-0000)
called number(111-222-3333) -> Cube -> (444-555-6666)
111-222-3333 = one of our DID's
444-555-6666 = External PSTN number
incoming callerID should be (000-000-0000).
Any idea how to accomplish this directly on the cube.
As per the debugs the incoming dial-peer is 0 and the outgoing dial-peer matched is 200 and to add to it the number is not getting translated. You need to make sure you have a VOIP dial-peer acting as an incoming dial-peer with incoming called-number .T specified in it and voice translation profile CFWD_PSTN applied to it.
Aseem
Aseem Anand
You can do this by:
1. Create a translation rule to translate the number:
voice translation-rule 1
rule 1 /1112223333/ 444555666/
2. Create a translation profile:
Voice translation-profile CFWD_PSTN
Translate called 1
3. Apply the translation-profile on the incoming dial-peer
dial-peer voice 1 voip
translation-profile incoming CFWD_PSTN
4. Create a specific voip dial-peer for that number:
dial-peer voice 2 voip
destination-pattern 444555666
session target ipv4:X.X.X.X
Aseem
(Please rate if useful)
Joli Martinez
Hello I am getting just ringing.  Also my SIP provider requires a prefix of 12345 which I have applied to the dial peer.
thanks,
rule 1 /111222333/ /444555666/
Translate called 1
destination-pattern 12345444555666
session target ipv4:1.1.1.1
*Oct 6 14:44:30.762: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:111222333@107.137.26.75 SIP/2.0
Record-Route: <sip:1.1.1.1;lr>
Max-Forwards: 66
Record-Route: <sip:216.115.69.132;lr>
To: <sip:+111222333@fl.gg>
From: <sip:+1000000000@fl.gg;isup-oli=00>;tag=gK040f257b
Via: SIP/2.0/UDP 1.1.1.1;branch=z9hG4bKa5af.91190bbacb2abe53b562a58a75ad15cc.0
Via: SIP/2.0/UDP 216.115.69.131;branch=z9hG4bKa5af.ffd54d3d91941e790979cb1250b8b00f.1
Via: SIP/2.0/UDP 216.115.69.132;branch=z9hG4bKa5af.d15072594d38b10038f1fb9f7bb34308.0
Via: SIP/2.0/UDP 2.2.2.2:5060;branch=z9hG4bK04B2849a2c368d3c54f
Call-ID: 140772495_129860044@2.2.2.2
CSeq: 789990 INVITE
Contact: <sip:+1000000000@2.2.2.2:5060>
Session-Expires: 1800
Min-SE: 90
Content-Length: 223
Content-Type: application/sdp
P-Asserted-Identity: <sip:+1000000000@fl.gg>
v=0
o=- 736619 371426 IN IP4 74.120.93.196
s=-
c=IN IP4 74.120.93.196
t=0 0
m=audio 43966 RTP/AVP 0 8 18 101
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=ptime:20
*Oct 6 14:44:30.766: //-1/393DDF5781AE/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=+1000000000
----- ccCallInfo IE subfields -----
cisco-ani=+1000000000
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=111222333
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
*Oct 6 14:44:30.770: //-1/393DDF5781AE/CCAPI/cc_api_call_setup_ind_common:
Interface=0x234D40CC, Call Info(
Calling Number=+1000000000,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=111222333(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=0, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=108
*Oct 6 14:44:30.770: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Oct 6 14:44:30.770: :cc_get_feature_vsa malloc success
*Oct 6 14:44:30.770: cc_get_feature_vsa count is 1
*Oct 6 14:44:30.770: :FEATURE_VSA attributes are: feature_name:0,feature_time:594239680,feature_id:97
*Oct 6 14:44:30.770: //108/393DDF5781AE/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=+1000000000(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=111222333(TON=Unknown, NPI=Unknown))
*Oct 6 14:44:30.770: //108/393DDF5781AE/CCAPI/cc_process_call_setup_ind:
Event=0x236E47F8
*Oct 6 14:44:30.770: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 111222333
*Oct 6 14:44:30.770: //108/393DDF5781AE/CCAPI/ccCallSetContext:
Context=0x21DB2110
>>>>CCAPI handed cid 108 with tag 0 to app "_ManagedAppProcess_Default"
*Oct 6 14:44:30.770: //108/393DDF5781AE/CCAPI/ccCallProceeding:
*Oct 6 14:44:30.770: //108/393DDF5781AE/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=200, Params=0x21DB0CF0, Progress Indication=NULL(0)
*Oct 6 14:44:30.770: //108/393DDF5781AE/CCAPI/ccCheckClipClir:
In: Calling Number=+1000000000(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Out: Calling Number=+1000000000(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Destination Pattern=1[2-9]..[2-9]......, Called Number=111222333, Digit Strip=FALSE
Redirect Number=, Display Info=
Account Number=+1000000000, Final Destination Flag=TRUE,
Guid=393DDF57-8B0A-11E6-81AE-9741F81B29EF, Outgoing Dial-peer=200
*Oct 6 14:44:30.770: //108/393DDF5781AE/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=111222333
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
*Oct 6 14:44:30.770: //108/393DDF5781AE/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x234D40CC, Interface Type=3, Destination=, Mode=0x0,
Call Params(Calling Number=+1000000000,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=111222333(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=200, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
*Oct 6 14:44:30.770: cc_get_feature_vsa count is 2
*Oct 6 14:44:30.770: :FEATURE_VSA attributes are: feature_name:0,feature_time:594239904,feature_id:98
*Oct 6 14:44:30.774: //109/393DDF5781AE/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
*Oct 6 14:44:30.774: //109/393DDF5781AE/CCAPI/ccCallSetContext:
Context=0x21DB0CA0
*Oct 6 14:44:30.774: //108/393DDF5781AE/CCAPI/ccSaveDialpeerTag:
*Oct 6 14:44:30.774: //109/393DDF5781AE/CCAPI/ccGetMediaClassTag:
media class tag 0
*Oct 6 14:44:30.774: //109/393DDF5781AE/CCAPI/ccSetMediaclassIp2ipTags:
media class tags set: NR 0, ASP 0
*Oct 6 14:44:30.774: //108/393DDF5781AE/CCAPI/ccGetMediaClassTag:
no peer tag found, use the default media class tag
*Oct 6 14:44:30.774: //108/393DDF5781AE/CCAPI/ccSetMediaclassIp2ipTags:
*Oct 6 14:44:30.774: //109/393DDF5781AE/CCAPI/ccGet_xc_nr_asp_info:
media class tags: NR 0, ASP 0
*Oct 6 14:44:30.774: //108/393DDF5781AE/CCAPI/ccGet_xc_nr_asp_info:
*Oct 6 14:44:30.774: //109/393DDF5781AE/CCAPI/cc_api_event_indication:
Event=188, Call Id=109
Event Is Sent To Conferenced SPI(s) Directly
*Oct 6 14:44:30.774: //108/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Oct 6 14:44:30.774: cc_api_get_xcode_stream : 4819
*Oct 6 14:44:30.774: //109/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Oct 6 14:44:30.774: //109/393DDF5781AE/CCAPI/cc_api_call_proceeding:
Interface=0x234D40CC, Progress Indication=NULL(0)
*Oct 6 14:44:30.778: //109/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Oct 6 14:44:30.778: cc_api_get_xcode_stream : 4819
*Oct 6 14:44:30.778: //108/393DDF5781AE/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 1.1.1.1;branch=z9hG4bKa5af.91190bbacb2abe53b562a58a75ad15cc.0,SIP/2.0/UDP 216.115.69.131;branch=z9hG4bKa5af.ffd54d3d91941e790979cb1250b8b00f.1,SIP/2.0/UDP 216.115.69.132;branch=z9hG4bKa5af.d15072594d38b10038f1fb9f7bb34308.0,SIP/2.0/UDP 2.2.2.2:5060;branch=z9hG4bK04B2849a2c368d3c54f
Date: Thu, 06 Oct 2016 14:44:30 GMT
CSeq: 789990 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-15.2.4.M7
Content-Length: 0
*Oct 6 14:44:30.778: //109/393DDF5781AE/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:111222333@1.1.1.1:5060 SIP/2.0
Via: SIP/2.0/UDP 107.137.26.75:5060;branch=z9hG4bK157CC
Remote-Party-ID: <sip:+1000000000@107.137.26.75>;party=calling;screen=no;privacy=off
From: <sip:+1000000000@107.137.26.75>;tag=19246FE0-196D
To: <sip:111222333@1.1.1.1>
Call-ID: 393F17A7-8B0A11E6-81B49741-F81B29EF@107.137.26.75
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 0960356183-2332692966-2175702849-4162529775
User-Agent: Cisco-SIPGateway/IOS-15.2.4.M7
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1475765070
Contact: <sip:+1000000000@107.137.26.75:5060>
Expires: 180
Max-Forwards: 65
Content-Disposition: session;handling=required
Content-Length: 250
v=0
o=CiscoSystemsSIP-GW-UserAgent 7944 3504 IN IP4 107.137.26.75
s=SIP Call
c=IN IP4 107.137.26.75
t=0 0
m=audio 16578 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=fmtp:101 0-15
a=ptime:20
*Oct 6 14:44:30.858: //109/393DDF5781AE/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
*Oct 6 14:44:30.898: //109/393DDF5781AE/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 407 Proxy Authentication Required
Via: SIP/2.0/UDP 107.137.26.75:5060;rport=56137;branch=z9hG4bK157CC
To: <sip:111222333@1.1.1.1>;tag=870a5b262384e4f9f82f59836d699db5.b0b1
CSeq: 101 INVITE
Proxy-Authenticate: Digest realm="sip.flowroute.com", nonce="V/Zqmlf2aW6o91QdvWKfIbHf+6j3SsNn", qop="auth"
Content-Length: 0
*Oct 6 14:44:30.902: //109/393DDF5781AE/CCAPI/cc_api_call_disconnected:
Cause Value=47, Interface=0x234D40CC, Call Id=109
Call Entry(Responsed=TRUE, Cause Value=47, Retry Count=0)
*Oct 6 14:44:30.902: //108/393DDF5781AE/CCAPI/ccCallReleaseResources:
release reserved xcoding resource.
*Oct 6 14:44:30.902: //109/393DDF5781AE/CCAPI/ccCallSetAAA_Accounting:
Accounting=0, Call Id=109
*Oct 6 14:44:30.902: //109/393DDF5781AE/CCAPI/ccCallDisconnect:
Cause Value=47, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=47)
Cause Value=47, Call Entry(Responsed=TRUE, Cause Value=47)
*Oct 6 14:44:30.902: //109/393DDF5781AE/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x234D40CC, Tag=0x0, Call Id=109,
Call Entry(Disconnect Cause=47, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
*Oct 6 14:44:30.902: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Oct 6 14:44:30.902: :cc_free_feature_vsa freeing 236B6198
*Oct 6 14:44:30.902: vsacount in free is 1
*Oct 6 14:44:30.902: //108/393DDF5781AE/CCAPI/ccCallDisconnect:
Cause Value=47, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
*Oct 6 14:44:30.902: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:111222333@1.1.1.1:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
*Oct 6 14:44:30.902: //108/393DDF5781AE/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 503 Service Unavailable
To: <sip:+111222333@fl.gg>;tag=19247060-1659
CSeq: 789990 INVITE
Reason: Q.850;cause=47
Content-Length: 0
*Oct 6 14:44:30.982: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:111222333@107.137.26.75 SIP/2.0
Max-Forwards: 66
CSeq: 789990 ACK
Content-Length: 0
*Oct 6 14:44:30.982: //108/393DDF5781AE/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x234D40CC, Tag=0x0, Call Id=108,
*Oct 6 14:44:30.982: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Oct 6 14:44:30.982: :cc_free_feature_vsa freeing 236B60B8
*Oct 6 14:44:30.982: vsacount in free is 0
*Oct 6 14:44:31.870: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 66
Via: SIP/2.0/UDP 1.1.1.1;branch=z9hG4bK13cc.17c65b6cd8afeb656d308a3d3933d992.0
Via: SIP/2.0/UDP 216.115.69.131;branch=z9hG4bK13cc.7471afea16664b3f1c4112be246b2e9a.1
Via: SIP/2.0/UDP 216.115.69.132;branch=z9hG4bK13cc.b59ba2b0406a90235c32573d78232497.0
Via: SIP/2.0/UDP 2.2.2.2:5060;branch=z9hG4bK04B2860ac2069a6373d
Call-ID: 140772525_129294173@2.2.2.2
CSeq: 140508 INVITE
Min-SE: 90
Content-Length: 223
v=0
o=- 529198 610829 IN IP4 74.120.93.196
s=-
t=0 0
m=audio 44344 RTP/AVP 0 8 18 101
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=ptime:20
*Oct 6 14:44:31.870: //-1/39E6544881B5/CCAPI/cc_api_display_ie_subfields:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=111222333
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
*Oct 6 14:44:31.874: //-1/39E6544881B5/CCAPI/cc_api_call_setup_ind_common:
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=110
*Oct 6 14:44:31.874: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Oct 6 14:44:31.874: :cc_get_feature_vsa malloc success
*Oct 6 14:44:31.874: cc_get_feature_vsa count is 1
*Oct 6 14:44:31.874: :FEATURE_VSA attributes are: feature_name:0,feature_time:594239680,feature_id:99
*Oct 6 14:44:31.874: //110/39E6544881B5/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
*Oct 6 14:44:31.874: //110/39E6544881B5/CCAPI/cc_process_call_setup_ind:
Event=0x236E47F8
*Oct 6 14:44:31.874: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
*Oct 6 14:44:31.874: //110/39E6544881B5/CCAPI/ccCallSetContext:
Context=0x21DB49F0
>>>>CCAPI handed cid 110 with tag 0 to app "_ManagedAppProcess_Default"
*Oct 6 14:44:31.874: //110/39E6544881B5/CCAPI/ccCallProceeding:
*Oct 6 14:44:31.874: //110/39E6544881B5/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=200, Params=0x21DB35D0, Progress Indication=NULL(0)
*Oct 6 14:44:31.874: //110/39E6544881B5/CCAPI/ccCheckClipClir:
Guid=39E65448-8B0A-11E6-81B5-9741F81B29EF, Outgoing Dial-peer=200
*Oct 6 14:44:31.874: //110/39E6544881B5/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=111222333
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
*Oct 6 14:44:31.874: //110/39E6544881B5/CCAPI/ccIFCallSetupRequestPrivate:
*Oct 6 14:44:31.874: cc_get_feature_vsa count is 2
*Oct 6 14:44:31.874: :FEATURE_VSA attributes are: feature_name:0,feature_time:594239904,feature_id:100
*Oct 6 14:44:31.878: //111/39E6544881B5/CCAPI/ccIFCallSetupRequestPrivate:
*Oct 6 14:44:31.878: //111/39E6544881B5/CCAPI/ccCallSetContext:
Context=0x21DB3580
*Oct 6 14:44:31.878: //110/39E6544881B5/CCAPI/ccSaveDialpeerTag:
*Oct 6 14:44:31.878: //111/39E6544881B5/CCAPI/ccGetMediaClassTag:
media class tag 0
*Oct 6 14:44:31.878: //111/39E6544881B5/CCAPI/ccSetMediaclassIp2ipTags:
*Oct 6 14:44:31.878: //110/39E6544881B5/CCAPI/ccGetMediaClassTag:
*Oct 6 14:44:31.878: //110/39E6544881B5/CCAPI/ccSetMediaclassIp2ipTags:
*Oct 6 14:44:31.878: //111/39E6544881B5/CCAPI/ccGet_xc_nr_asp_info:
*Oct 6 14:44:31.878: //110/39E6544881B5/CCAPI/ccGet_xc_nr_asp_info:
*Oct 6 14:44:31.878: //111/39E6544881B5/CCAPI/cc_api_event_indication:
Event=188, Call Id=111
*Oct 6 14:44:31.878: //110/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Oct 6 14:44:31.878: cc_api_get_xcode_stream : 4819
*Oct 6 14:44:31.878: //111/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Oct 6 14:44:31.878: //111/39E6544881B5/CCAPI/cc_api_call_proceeding:
*Oct 6 14:44:31.882: //111/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Oct 6 14:44:31.882: cc_api_get_xcode_stream : 4819
*Oct 6 14:44:31.882: //110/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Oct 6 14:44:31.882: //110/39E6544881B5/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 1.1.1.1;branch=z9hG4bK13cc.17c65b6cd8afeb656d308a3d3933d992.0,SIP/2.0/UDP 216.115.69.131;branch=z9hG4bK13cc.7471afea16664b3f1c4112be246b2e9a.1,SIP/2.0/UDP 216.115.69.132;branch=z9hG4bK13cc.b59ba2b0406a90235c32573d78232497.0,SIP/2.0/UDP 2.2.2.2:5060;branch=z9hG4bK04B2860ac2069a6373d
Date: Thu, 06 Oct 2016 14:44:31 GMT
CSeq: 140508 INVITE
Content-Length: 0
*Oct 6 14:44:31.882: //111/39E6544881B5/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 107.137.26.75:5060;branch=z9hG4bK161125
From: <sip:+1000000000@107.137.26.75>;tag=19247430-4A8
Call-ID: 39E78C98-8B0A11E6-81BB9741-F81B29EF@107.137.26.75
Min-SE: 1800
Cisco-Guid: 0971396168-2332692966-2176161601-4162529775
CSeq: 101 INVITE
Timestamp: 1475765071
Expires: 180
Max-Forwards: 65
Content-Length: 250
v=0
o=CiscoSystemsSIP-GW-UserAgent 1223 9249 IN IP4 107.137.26.75
s=SIP Call
t=0 0
m=audio 16582 RTP/AVP 0 101
a=fmtp:101 0-15
a=ptime:20
*Oct 6 14:44:31.958: //111/39E6544881B5/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
*Oct 6 14:44:32.002: //111/39E6544881B5/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 107.137.26.75:5060;rport=56137;branch=z9hG4bK161125
To: <sip:111222333@1.1.1.1>;tag=870a5b262384e4f9f82f59836d699db5.4d98
CSeq: 101 INVITE
Proxy-Authenticate: Digest realm="sip.flowroute.com", nonce="V/Zqm1f2aW86SKEHYMjw42ZOE8c75KDv", qop="auth"
Content-Length: 0
*Oct 6 14:44:32.002: //111/39E6544881B5/CCAPI/cc_api_call_disconnected:
Cause Value=47, Interface=0x234D40CC, Call Id=111
*Oct 6 14:44:32.002: //110/39E6544881B5/CCAPI/ccCallReleaseResources:
*Oct 6 14:44:32.002: //111/39E6544881B5/CCAPI/ccCallSetAAA_Accounting:
Accounting=0, Call Id=111
*Oct 6 14:44:32.002: //111/39E6544881B5/CCAPI/ccCallDisconnect:
*Oct 6 14:44:32.002: //111/39E6544881B5/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x234D40CC, Tag=0x0, Call Id=111,
*Oct 6 14:44:32.002: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Oct 6 14:44:32.002: :cc_free_feature_vsa freeing 236B6198
*Oct 6 14:44:32.002: vsacount in free is 1
*Oct 6 14:44:32.002: //110/39E6544881B5/CCAPI/ccCallDisconnect:
*Oct 6 14:44:32.006: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
*Oct 6 14:44:32.006: //110/39E6544881B5/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:+111222333@fl.gg>;tag=192474AC-176D
CSeq: 140508 INVITE
Content-Length: 0
*Oct 6 14:44:32.082: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 66
CSeq: 140508 ACK
Content-Length: 0
*Oct 6 14:44:32.082: //110/39E6544881B5/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x234D40CC, Tag=0x0, Call Id=110,
*Oct 6 14:44:32.082: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Oct 6 14:44:32.082: :cc_free_feature_vsa freeing 236B60B8
*Oct 6 14:44:32.082: vsacount in free is 0
*Oct 6 14:44:32.830: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 66
Via: SIP/2.0/UDP 1.1.1.1;branch=z9hG4bK4213.882056db2f301b5cf2ff273cb6e0e45e.0
Via: SIP/2.0/UDP 216.115.69.131;branch=z9hG4bK4213.2355a72ea6c411a22f27a55c4f2affab.1
Via: SIP/2.0/UDP 216.115.69.132;branch=z9hG4bK4213.c8f60f91be54347b350601a6b28f9161.0
Via: SIP/2.0/UDP 74.120.93.200:5060;branch=z9hG4bK0cBb95199d8e7b432d4
Call-ID: 1462539362_67030934@74.120.93.200
CSeq: 396147 INVITE
Contact: <sip:+1000000000@74.120.93.200:5060>
Min-SE: 90
Content-Length: 222
v=0
o=- 147644 14498 IN IP4 74.120.93.202
s=-
c=IN IP4 74.120.93.202
t=0 0
m=audio 24570 RTP/AVP 0 8 18 101
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=ptime:20
*Oct 6 14:44:32.834: //-1/3A78D00781BC/CCAPI/cc_api_display_ie_subfields:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=111222333
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
*Oct 6 14:44:32.834: //-1/3A78D00781BC/CCAPI/cc_api_call_setup_ind_common:
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=112
*Oct 6 14:44:32.834: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Oct 6 14:44:32.834: :cc_get_feature_vsa malloc success
*Oct 6 14:44:32.834: cc_get_feature_vsa count is 1
*Oct 6 14:44:32.834: :FEATURE_VSA attributes are: feature_name:0,feature_time:594239680,feature_id:101
*Oct 6 14:44:32.834: //112/3A78D00781BC/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
*Oct 6 14:44:32.834: //112/3A78D00781BC/CCAPI/cc_process_call_setup_ind:
Event=0x236E47F8
*Oct 6 14:44:32.834: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
*Oct 6 14:44:32.834: //112/3A78D00781BC/CCAPI/ccCallSetContext:
Context=0x21D9DA10
>>>>CCAPI handed cid 112 with tag 0 to app "_ManagedAppProcess_Default"
*Oct 6 14:44:32.834: //112/3A78D00781BC/CCAPI/ccCallProceeding:
*Oct 6 14:44:32.834: //112/3A78D00781BC/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=200, Params=0x21D9C5F0, Progress Indication=NULL(0)
*Oct 6 14:44:32.834: //112/3A78D00781BC/CCAPI/ccCheckClipClir:
Guid=3A78D007-8B0A-11E6-81BC-9741F81B29EF, Outgoing Dial-peer=200
*Oct 6 14:44:32.834: //112/3A78D00781BC/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=111222333
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
*Oct 6 14:44:32.838: //112/3A78D00781BC/CCAPI/ccIFCallSetupRequestPrivate:
*Oct 6 14:44:32.838: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Oct 6 14:44:32.838: :cc_get_feature_vsa malloc success
*Oct 6 14:44:32.838: cc_get_feature_vsa count is 2
*Oct 6 14:44:32.838: :FEATURE_VSA attributes are: feature_name:0,feature_time:594239904,feature_id:102
*Oct 6 14:44:32.838: //113/3A78D00781BC/CCAPI/ccIFCallSetupRequestPrivate:
*Oct 6 14:44:32.838: //113/3A78D00781BC/CCAPI/ccCallSetContext:
Context=0x21D9C5A0
*Oct 6 14:44:32.838: //112/3A78D00781BC/CCAPI/ccSaveDialpeerTag:
*Oct 6 14:44:32.838: //113/3A78D00781BC/CCAPI/ccGetMediaClassTag:
media class tag 0
*Oct 6 14:44:32.838: //113/3A78D00781BC/CCAPI/ccSetMediaclassIp2ipTags:
*Oct 6 14:44:32.838: //112/3A78D00781BC/CCAPI/ccGetMediaClassTag:
*Oct 6 14:44:32.838: //112/3A78D00781BC/CCAPI/ccSetMediaclassIp2ipTags:
*Oct 6 14:44:32.838: //113/3A78D00781BC/CCAPI/ccGet_xc_nr_asp_info:
*Oct 6 14:44:32.838: //112/3A78D00781BC/CCAPI/ccGet_xc_nr_asp_info:
*Oct 6 14:44:32.838: //113/3A78D00781BC/CCAPI/cc_api_event_indication:
Event=188, Call Id=113
*Oct 6 14:44:32.838: //112/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Oct 6 14:44:32.838: cc_api_get_xcode_stream : 4819
*Oct 6 14:44:32.838: //113/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Oct 6 14:44:32.838: //113/3A78D00781BC/CCAPI/cc_api_call_proceeding:
*Oct 6 14:44:32.842: //113/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Oct 6 14:44:32.842: cc_api_get_xcode_stream : 4819
*Oct 6 14:44:32.842: //112/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Oct 6 14:44:32.842: //112/3A78D00781BC/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 1.1.1.1;branch=z9hG4bK4213.882056db2f301b5cf2ff273cb6e0e45e.0,SIP/2.0/UDP 216.115.69.131;branch=z9hG4bK4213.2355a72ea6c411a22f27a55c4f2affab.1,SIP/2.0/UDP 216.115.69.132;branch=z9hG4bK4213.c8f60f91be54347b350601a6b28f9161.0,SIP/2.0/UDP 74.120.93.200:5060;branch=z9hG4bK0cBb95199d8e7b432d4
Date: Thu, 06 Oct 2016 14:44:32 GMT
CSeq: 396147 INVITE
Content-Length: 0
*Oct 6 14:44:32.842: //113/3A78D00781BC/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 107.137.26.75:5060;branch=z9hG4bK171BCB
From: <sip:+1000000000@107.137.26.75>;tag=192477F0-E72
Call-ID: 3A7A08F0-8B0A11E6-81C29741-F81B29EF@107.137.26.75
Min-SE: 1800
Cisco-Guid: 0980996103-2332692966-2176620353-4162529775
CSeq: 101 INVITE
Timestamp: 1475765072
Expires: 180
Max-Forwards: 65
Content-Length: 249
v=0
o=CiscoSystemsSIP-GW-UserAgent 791 1715 IN IP4 107.137.26.75
s=SIP Call
t=0 0
m=audio 16586 RTP/AVP 0 101
a=fmtp:101 0-15
a=ptime:20
*Oct 6 14:44:33.254: //113/3A78D00781BC/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
*Oct 6 14:44:33.258: //113/3A78D00781BC/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 107.137.26.75:5060;rport=56137;branch=z9hG4bK171BCB
To: <sip:111222333@1.1.1.1>;tag=870a5b262384e4f9f82f59836d699db5.4cdb
CSeq: 101 INVITE
Proxy-Authenticate: Digest realm="sip.flowroute.com", nonce="V/ZqnFf2aXA6SekP2Xfqh33RHTtzQsMT", qop="auth"
Content-Length: 0
*Oct 6 14:44:33.258: //113/3A78D00781BC/CCAPI/cc_api_call_disconnected:
Cause Value=47, Interface=0x234D40CC, Call Id=113
*Oct 6 14:44:33.258: //112/3A78D00781BC/CCAPI/ccCallReleaseResources:
*Oct 6 14:44:33.258: //113/3A78D00781BC/CCAPI/ccCallSetAAA_Accounting:
Accounting=0, Call Id=113
*Oct 6 14:44:33.258: //113/3A78D00781BC/CCAPI/ccCallDisconnect:
*Oct 6 14:44:33.258: //113/3A78D00781BC/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x234D40CC, Tag=0x0, Call Id=113,
*Oct 6 14:44:33.258: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Oct 6 14:44:33.258: :cc_free_feature_vsa freeing 236B6198
*Oct 6 14:44:33.258: vsacount in free is 1
*Oct 6 14:44:33.258: //112/3A78D00781BC/CCAPI/ccCallDisconnect:
*Oct 6 14:44:33.262: //112/3A78D00781BC/CCAPI/ccCallDisconnect:
*Oct 6 14:44:33.262: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
*Oct 6 14:44:33.262: //112/3A78D00781BC/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:+111222333@fl.gg>;tag=19247998-847
CSeq: 396147 INVITE
Content-Length: 0
*Oct 6 14:44:33.918: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 66
CSeq: 396147 ACK
Content-Length: 0
*Oct 6 14:44:33.918: //112/3A78D00781BC/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x234D40CC, Tag=0x0, Call Id=112,
*Oct 6 14:44:33.918: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Oct 6 14:44:33.918: :cc_free_feature_vsa freeing 236B60B8
*Oct 6 14:44:33.918: vsacount in free is 0
*Oct 6 14:44:35.978: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 66
Via: SIP/2.0/UDP 1.1.1.1;branch=z9hG4bK977e.713b78c9a373fad9e49e48c48fd44b32.0
Via: SIP/2.0/UDP 216.115.69.131;branch=z9hG4bK977e.3b8037d71cb303738f141cab8e22cff0.1
Via: SIP/2.0/UDP 216.115.69.132;branch=z9hG4bK977e.cc9bacf49268a75b0d84f1ea17242c96.0
Via: SIP/2.0/UDP 74.120.93.200:5060;branch=z9hG4bK0cBb9f34a8d4d241749
Call-ID: 1462539447_133951755@74.120.93.200
CSeq: 182019 INVITE
Min-SE: 90
Content-Length: 223
v=0
o=- 907386 591733 IN IP4 74.120.93.201
s=-
c=IN IP4 74.120.93.201
t=0 0
m=audio 15128 RTP/AVP 0 8 18 101
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=ptime:20
*Oct 6 14:44:35.982: //-1/3C5928E181C3/CCAPI/cc_api_display_ie_subfields:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=111222333
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
*Oct 6 14:44:35.982: //-1/3C5928E181C3/CCAPI/cc_api_call_setup_ind_common:
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=114
*Oct 6 14:44:35.982: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Oct 6 14:44:35.982: :cc_get_feature_vsa malloc success
*Oct 6 14:44:35.982: cc_get_feature_vsa count is 1
*Oct 6 14:44:35.982: :FEATURE_VSA attributes are: feature_name:0,feature_time:594239680,feature_id:103
*Oct 6 14:44:35.982: //114/3C5928E181C3/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
*Oct 6 14:44:35.982: //114/3C5928E181C3/CCAPI/cc_process_call_setup_ind:
Event=0x236E47F8
*Oct 6 14:44:35.982: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
*Oct 6 14:44:35.982: //114/3C5928E181C3/CCAPI/ccCallSetContext:
Context=0x21DA02F0
>>>>CCAPI handed cid 114 with tag 0 to app "_ManagedAppProcess_Default"
*Oct 6 14:44:35.982: //114/3C5928E181C3/CCAPI/ccCallProceeding:
*Oct 6 14:44:35.986: //114/3C5928E181C3/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=200, Params=0x21D9EED0, Progress Indication=NULL(0)
*Oct 6 14:44:35.986: //114/3C5928E181C3/CCAPI/ccCheckClipClir:
Guid=3C5928E1-8B0A-11E6-81C3-9741F81B29EF, Outgoing Dial-peer=200
*Oct 6 14:44:35.986: //114/3C5928E181C3/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=111222333
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
*Oct 6 14:44:35.986: //114/3C5928E181C3/CCAPI/ccIFCallSetupRequestPrivate:
*Oct 6 14:44:35.986: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Oct 6 14:44:35.986: :cc_get_feature_vsa malloc success
*Oct 6 14:44:35.986: cc_get_feature_vsa count is 2
*Oct 6 14:44:35.986: :FEATURE_VSA attributes are: feature_name:0,feature_time:594239904,feature_id:104
*Oct 6 14:44:35.986: //115/3C5928E181C3/CCAPI/ccIFCallSetupRequestPrivate:
*Oct 6 14:44:35.986: //115/3C5928E181C3/CCAPI/ccCallSetContext:
Context=0x21D9EE80
*Oct 6 14:44:35.986: //114/3C5928E181C3/CCAPI/ccSaveDialpeerTag:
*Oct 6 14:44:35.986: //115/3C5928E181C3/CCAPI/ccGetMediaClassTag:
media class tag 0
*Oct 6 14:44:35.986: //115/3C5928E181C3/CCAPI/ccSetMediaclassIp2ipTags:
*Oct 6 14:44:35.986: //114/3C5928E181C3/CCAPI/ccGetMediaClassTag:
*Oct 6 14:44:35.986: //114/3C5928E181C3/CCAPI/ccSetMediaclassIp2ipTags:
*Oct 6 14:44:35.986: //115/3C5928E181C3/CCAPI/ccGet_xc_nr_asp_info:
*Oct 6 14:44:35.986: //114/3C5928E181C3/CCAPI/ccGet_xc_nr_asp_info:
*Oct 6 14:44:35.986: //115/3C5928E181C3/CCAPI/cc_api_event_indication:
Event=188, Call Id=115
*Oct 6 14:44:35.986: //114/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Oct 6 14:44:35.986: cc_api_get_xcode_stream : 4819
*Oct 6 14:44:35.986: //115/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Oct 6 14:44:35.990: //115/3C5928E181C3/CCAPI/cc_api_call_proceeding:
*Oct 6 14:44:35.990: //115/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Oct 6 14:44:35.990: cc_api_get_xcode_stream : 4819
*Oct 6 14:44:35.990: //114/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Oct 6 14:44:35.990: //114/3C5928E181C3/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 1.1.1.1;branch=z9hG4bK977e.713b78c9a373fad9e49e48c48fd44b32.0,SIP/2.0/UDP 216.115.69.131;branch=z9hG4bK977e.3b8037d71cb303738f141cab8e22cff0.1,SIP/2.0/UDP 216.115.69.132;branch=z9hG4bK977e.cc9bacf49268a75b0d84f1ea17242c96.0,SIP/2.0/UDP 74.120.93.200:5060;branch=z9hG4bK0cBb9f34a8d4d241749
Date: Thu, 06 Oct 2016 14:44:35 GMT
CSeq: 182019 INVITE
Content-Length: 0
*Oct 6 14:44:35.990: //115/3C5928E181C3/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 107.137.26.75:5060;branch=z9hG4bK18230C
From: <sip:+1000000000@107.137.26.75>;tag=19248440-1BC7
Call-ID: 3C5AFD59-8B0A11E6-81C99741-F81B29EF@107.137.26.75
Min-SE: 1800
Cisco-Guid: 1012476129-2332692966-2177079105-4162529775
CSeq: 101 INVITE
Timestamp: 1475765075
Expires: 180
Max-Forwards: 65
Content-Length: 249
v=0
o=CiscoSystemsSIP-GW-UserAgent 2142 587 IN IP4 107.137.26.75
s=SIP Call
t=0 0
m=audio 16590 RTP/AVP 0 101
a=fmtp:101 0-15
a=ptime:20
*Oct 6 14:44:36.446: //115/3C5928E181C3/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
*Oct 6 14:44:36.454: //115/3C5928E181C3/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 107.137.26.75:5060;rport=56137;branch=z9hG4bK18230C
To: <sip:111222333@1.1.1.1>;tag=870a5b262384e4f9f82f59836d699db5.b1e8
CSeq: 101 INVITE
Proxy-Authenticate: Digest realm="sip.flowroute.com", nonce="V/Zqn1f2aXPrIpYfhW/SieK7KKAV0l6l", qop="auth"
Content-Length: 0
*Oct 6 14:44:36.454: //115/3C5928E181C3/CCAPI/cc_api_call_disconnected:
Cause Value=47, Interface=0x234D40CC, Call Id=115
*Oct 6 14:44:36.458: //114/3C5928E181C3/CCAPI/ccCallReleaseResources:
*Oct 6 14:44:36.458: //115/3C5928E181C3/CCAPI/ccCallSetAAA_Accounting:
Accounting=0, Call Id=115
*Oct 6 14:44:36.458: //115/3C5928E181C3/CCAPI/ccCallDisconnect:
*Oct 6 14:44:36.458: //115/3C5928E181C3/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x234D40CC, Tag=0x0, Call Id=115,
*Oct 6 14:44:36.458: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Oct 6 14:44:36.458: :cc_free_feature_vsa freeing 236B6198
*Oct 6 14:44:36.458: vsacount in free is 1
*Oct 6 14:44:36.458: //114/3C5928E181C3/CCAPI/ccCallDisconnect:
*Oct 6 14:44:36.462: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
*Oct 6 14:44:36.462: //114/3C5928E181C3/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:+111222333@fl.gg>;tag=19248614-1ACE
CSeq: 182019 INVITE
Content-Length: 0
*Oct 6 14:44:36.750: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 66
CSeq: 182019 ACK
Content-Length: 0
*Oct 6 14:44:36.750: //114/3C5928E181C3/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x234D40CC, Tag=0x0, Call Id=114,
*Oct 6 14:44:36.750: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Oct 6 14:44:36.750: :cc_free_feature_vsa freeing 236B60B8
*Oct 6 14:44:36.750: vsacount in free is 0
*Oct 6 14:44:37.974: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 66
Via: SIP/2.0/UDP 1.1.1.1;branch=z9hG4bKcd8e.9fd42d3ac9568a0352c98fd10ead9954.0
Via: SIP/2.0/UDP 216.115.69.131;branch=z9hG4bKcd8e.34e6c51c6371a506833024e89fea2946.1
Via: SIP/2.0/UDP 216.115.69.132;branch=z9hG4bKcd8e.caca915912a6128b657afbb9ff71b4d4.0
Via: SIP/2.0/UDP 74.120.93.200:5060;branch=z9hG4bK08B8d9ba2325af1e3d3
Call-ID: 1460178549_129844911@74.120.93.200
CSeq: 326380 INVITE
Min-SE: 90
Content-Length: 222
v=0
o=- 618487 77764 IN IP4 74.120.93.201
s=-
t=0 0
m=audio 47886 RTP/AVP 0 8 18 101
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=ptime:20
*Oct 6 14:44:37.978: //-1/3D89B92181CA/CCAPI/cc_api_display_ie_subfields:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=111222333
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
*Oct 6 14:44:37.978: //-1/3D89B92181CA/CCAPI/cc_api_call_setup_ind_common:
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=116
*Oct 6 14:44:37.978: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Oct 6 14:44:37.978: :cc_get_feature_vsa malloc success
*Oct 6 14:44:37.978: cc_get_feature_vsa count is 1
*Oct 6 14:44:37.978: :FEATURE_VSA attributes are: feature_name:0,feature_time:594239680,feature_id:105
*Oct 6 14:44:37.978: //116/3D89B92181CA/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
*Oct 6 14:44:37.982: //116/3D89B92181CA/CCAPI/cc_process_call_setup_ind:
Event=0x236E47F8
*Oct 6 14:44:37.982: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
*Oct 6 14:44:37.982: //116/3D89B92181CA/CCAPI/ccCallSetContext:
Context=0x21DA1760
>>>>CCAPI handed cid 116 with tag 0 to app "_ManagedAppProcess_Default"
*Oct 6 14:44:37.986: //116/3D89B92181CA/CCAPI/ccCallProceeding:
*Oct 6 14:44:37.986: //116/3D89B92181CA/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=200, Params=0x21DA2C20, Progress Indication=NULL(0)
*Oct 6 14:44:37.986: //116/3D89B92181CA/CCAPI/ccCheckClipClir:
Guid=3D89B921-8B0A-11E6-81CA-9741F81B29EF, Outgoing Dial-peer=200
*Oct 6 14:44:37.986: //116/3D89B92181CA/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=111222333
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
*Oct 6 14:44:37.990: //116/3D89B92181CA/CCAPI/ccIFCallSetupRequestPrivate:
*Oct 6 14:44:37.990: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Oct 6 14:44:37.990: :cc_get_feature_vsa malloc success
*Oct 6 14:44:37.990: cc_get_feature_vsa count is 2
*Oct 6 14:44:37.990: :FEATURE_VSA attributes are: feature_name:0,feature_time:594239904,feature_id:106
*Oct 6 14:44:37.990: //117/3D89B92181CA/CCAPI/ccIFCallSetupRequestPrivate:
*Oct 6 14:44:37.990: //117/3D89B92181CA/CCAPI/ccCallSetContext:
Context=0x21DA2BD0
*Oct 6 14:44:37.990: //116/3D89B92181CA/CCAPI/ccSaveDialpeerTag:
*Oct 6 14:44:37.990: //116/3D89B92181CA/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 1.1.1.1;branch=z9hG4bKcd8e.9fd42d3ac9568a0352c98fd10ead9954.0,SIP/2.0/UDP 216.115.69.131;branch=z9hG4bKcd8e.34e6c51c6371a506833024e89fea2946.1,SIP/2.0/UDP 216.115.69.132;branch=z9hG4bKcd8e.caca915912a6128b657afbb9ff71b4d4.0,SIP/2.0/UDP 74.120.93.200:5060;branch=z9hG4bK08B8d9ba2325af1e3d3
Date: Thu, 06 Oct 2016 14:44:37 GMT
CSeq: 326380 INVITE
Content-Length: 0
*Oct 6 14:44:37.990: //117/3D89B92181CA/CCAPI/ccGetMediaClassTag:
media class tag 0
*Oct 6 14:44:37.990: //117/3D89B92181CA/CCAPI/ccSetMediaclassIp2ipTags:
*Oct 6 14:44:37.990: //116/3D89B92181CA/CCAPI/ccGetMediaClassTag:
*Oct 6 14:44:37.990: //116/3D89B92181CA/CCAPI/ccSetMediaclassIp2ipTags:
*Oct 6 14:44:37.990: //117/3D89B92181CA/CCAPI/ccGet_xc_nr_asp_info:
*Oct 6 14:44:37.990: //116/3D89B92181CA/CCAPI/ccGet_xc_nr_asp_info:
*Oct 6 14:44:37.990: //117/3D89B92181CA/CCAPI/cc_api_event_indication:
Event=188, Call Id=117
*Oct 6 14:44:37.990: //116/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Oct 6 14:44:37.990: cc_api_get_xcode_stream : 4819
*Oct 6 14:44:37.990: //117/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Oct 6 14:44:37.994: //117/3D89B92181CA/CCAPI/cc_api_call_proceeding:
*Oct 6 14:44:37.994: //117/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Oct 6 14:44:37.994: cc_api_get_xcode_stream : 4819
*Oct 6 14:44:37.994: //116/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Oct 6 14:44:37.994: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 66
CSeq: 326380 INVITE
Min-SE: 90
Content-Length: 222
v=0
s=-
t=0 0
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=ptime:20
*Oct 6 14:44:37.994: //117/3D89B92181CA/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 107.137.26.75:5060;branch=z9hG4bK19B81
From: <sip:+1000000000@107.137.26.75>;tag=19248C14-1A08
Call-ID: 3D8C2A59-8B0A11E6-81D09741-F81B29EF@107.137.26.75
Min-SE: 1800
Cisco-Guid: 1032436001-2332692966-2177537857-4162529775
CSeq: 101 INVITE
Timestamp: 1475765077
Expires: 180
Max-Forwards: 65
Content-Length: 250
v=0
o=CiscoSystemsSIP-GW-UserAgent 4776 3544 IN IP4 107.137.26.75
s=SIP Call
t=0 0
m=audio 16594 RTP/AVP 0 101
a=fmtp:101 0-15
a=ptime:20
*Oct 6 14:44:37.994: //116/3D89B92181CA/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 326380 INVITE
Content-Length: 0
*Oct 6 14:44:38.330: //117/3D89B92181CA/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
*Oct 6 14:44:38.334: //117/3D89B92181CA/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 107.137.26.75:5060;rport=56137;branch=z9hG4bK19B81
To: <sip:111222333@1.1.1.1>;tag=870a5b262384e4f9f82f59836d699db5.9fd6
CSeq: 101 INVITE
Proxy-Authenticate: Digest realm="sip.flowroute.com", nonce="V/ZqoVf2aXU7voV31G9z3TdHzu/fPROg", qop="auth"
Content-Length: 0
*Oct 6 14:44:38.334: //117/3D89B92181CA/CCAPI/cc_api_call_disconnected:
Cause Value=47, Interface=0x234D40CC, Call Id=117
*Oct 6 14:44:38.334: //116/3D89B92181CA/CCAPI/ccCallReleaseResources:
*Oct 6 14:44:38.334: //117/3D89B92181CA/CCAPI/ccCallSetAAA_Accounting:
Accounting=0, Call Id=117
*Oct 6 14:44:38.334: //117/3D89B92181CA/CCAPI/ccCallDisconnect:
*Oct 6 14:44:38.334: //117/3D89B92181CA/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x234D40CC, Tag=0x0, Call Id=117,
*Oct 6 14:44:38.334: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Oct 6 14:44:38.334: :cc_free_feature_vsa freeing 236B6198
*Oct 6 14:44:38.334: vsacount in free is 1
*Oct 6 14:44:38.334: //116/3D89B92181CA/CCAPI/ccCallDisconnect:
*Oct 6 14:44:38.334: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
*Oct 6 14:44:38.338: //116/3D89B92181CA/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:+111222333@fl.gg>;tag=19248D68-761
CSeq: 326380 INVITE
Content-Length: 0
*Oct 6 14:44:38.794: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 66
CSeq: 326380 ACK
Content-Length: 0
*Oct 6 14:44:38.794: //116/3D89B92181CA/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x234D40CC, Tag=0x0, Call Id=116,
*Oct 6 14:44:38.794: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Oct 6 14:44:38.794: :cc_free_feature_vsa freeing 236B60B8
*Oct 6 14:44:38.794: vsacount in free is 0
*Oct 6 14:44:39.654: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 66
Via: SIP/2.0/UDP 1.1.1.1;branch=z9hG4bK7ac7.cc6fdac9f43a31a050ad2d01e5d5a0f3.0
Via: SIP/2.0/UDP 216.115.69.131;branch=z9hG4bK7ac7.28823bec98ae9b5cd449eac6e94f548e.1
Via: SIP/2.0/UDP 216.115.69.132;branch=z9hG4bK7ac7.83675f2b8664ed554127002ed2f6e904.0
Via: SIP/2.0/UDP 74.120.93.200:5060;branch=z9hG4bK00Bb425e41f0fa050d3
Call-ID: 1463851016_62793977@74.120.93.200
CSeq: 966322 INVITE
Min-SE: 90
Content-Length: 222
v=0
o=- 28114 786313 IN IP4 74.120.93.201
s=-
t=0 0
m=audio 21356 RTP/AVP 0 8 18 101
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=ptime:20
*Oct 6 14:44:39.658: //-1/3E8A131681D1/CCAPI/cc_api_display_ie_subfields:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=111222333
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
*Oct 6 14:44:39.658: //-1/3E8A131681D1/CCAPI/cc_api_call_setup_ind_common:
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=118
*Oct 6 14:44:39.658: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Oct 6 14:44:39.658: :cc_get_feature_vsa malloc success
*Oct 6 14:44:39.658: cc_get_feature_vsa count is 1
*Oct 6 14:44:39.658: :FEATURE_VSA attributes are: feature_name:0,feature_time:594239680,feature_id:107
*Oct 6 14:44:39.658: //118/3E8A131681D1/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
*Oct 6 14:44:39.658: //118/3E8A131681D1/CCAPI/cc_process_call_setup_ind:
Event=0x236E47F8
*Oct 6 14:44:39.658: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
*Oct 6 14:44:39.658: //118/3E8A131681D1/CCAPI/ccCallSetContext:
Context=0x21DA4040
>>>>CCAPI handed cid 118 with tag 0 to app "_ManagedAppProcess_Default"
*Oct 6 14:44:39.658: //118/3E8A131681D1/CCAPI/ccCallProceeding:
*Oct 6 14:44:39.658: //118/3E8A131681D1/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=200, Params=0x21DA5500, Progress Indication=NULL(0)
*Oct 6 14:44:39.658: //118/3E8A131681D1/CCAPI/ccCheckClipClir:
Guid=3E8A1316-8B0A-11E6-81D1-9741F81B29EF, Outgoing Dial-peer=200
*Oct 6 14:44:39.658: //118/3E8A131681D1/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=111222333
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
*Oct 6 14:44:39.658: //118/3E8A131681D1/CCAPI/ccIFCallSetupRequestPrivate:
*Oct 6 14:44:39.662: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Oct 6 14:44:39.662: :cc_get_feature_vsa malloc success
*Oct 6 14:44:39.662: cc_get_feature_vsa count is 2
*Oct 6 14:44:39.662: :FEATURE_VSA attributes are: feature_name:0,feature_time:594239904,feature_id:108
*Oct 6 14:44:39.662: //119/3E8A131681D1/CCAPI/ccIFCallSetupRequestPrivate:
*Oct 6 14:44:39.662: //119/3E8A131681D1/CCAPI/ccCallSetContext:
Context=0x21DA54B0
*Oct 6 14:44:39.662: //118/3E8A131681D1/CCAPI/ccSaveDialpeerTag:
*Oct 6 14:44:39.662: //118/3E8A131681D1/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 1.1.1.1;branch=z9hG4bK7ac7.cc6fdac9f43a31a050ad2d01e5d5a0f3.0,SIP/2.0/UDP 216.115.69.131;branch=z9hG4bK7ac7.28823bec98ae9b5cd449eac6e94f548e.1,SIP/2.0/UDP 216.115.69.132;branch=z9hG4bK7ac7.83675f2b8664ed554127002ed2f6e904.0,SIP/2.0/UDP 74.120.93.200:5060;branch=z9hG4bK00Bb425e41f0fa050d3
Date: Thu, 06 Oct 2016 14:44:39 GMT
CSeq: 966322 INVITE
Content-Length: 0
*Oct 6 14:44:39.662: //119/3E8A131681D1/CCAPI/ccGetMediaClassTag:
media class tag 0
*Oct 6 14:44:39.662: //119/3E8A131681D1/CCAPI/ccSetMediaclassIp2ipTags:
*Oct 6 14:44:39.662: //118/3E8A131681D1/CCAPI/ccGetMediaClassTag:
*Oct 6 14:44:39.662: //118/3E8A131681D1/CCAPI/ccSetMediaclassIp2ipTags:
*Oct 6 14:44:39.662: //119/3E8A131681D1/CCAPI/ccGet_xc_nr_asp_info:
*Oct 6 14:44:39.662: //118/3E8A131681D1/CCAPI/ccGet_xc_nr_asp_info:
*Oct 6 14:44:39.662: //119/3E8A131681D1/CCAPI/cc_api_event_indication:
Event=188, Call Id=119
*Oct 6 14:44:39.662: //118/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Oct 6 14:44:39.662: cc_api_get_xcode_stream : 4819
*Oct 6 14:44:39.662: //119/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Oct 6 14:44:39.662: //119/3E8A131681D1/CCAPI/cc_api_call_proceeding:
*Oct 6 14:44:39.666: //119/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Oct 6 14:44:39.666: cc_api_get_xcode_stream : 4819
*Oct 6 14:44:39.666: //118/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Oct 6 14:44:39.666: //119/3E8A131681D1/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 107.137.26.75:5060;branch=z9hG4bK1A20F1
From: <sip:+1000000000@107.137.26.75>;tag=1924929C-BDB
Call-ID: 3E8B4B66-8B0A11E6-81D79741-F81B29EF@107.137.26.75
Min-SE: 1800
Cisco-Guid: 1049236246-2332692966-2177996609-4162529775
CSeq: 101 INVITE
Timestamp: 1475765079
Expires: 180
Max-Forwards: 65
Content-Length: 250
v=0
o=CiscoSystemsSIP-GW-UserAgent 5113 8668 IN IP4 107.137.26.75
s=SIP Call
t=0 0
m=audio 16598 RTP/AVP 0 101
a=fmtp:101 0-15
a=ptime:20
*Oct 6 14:44:40.542: //119/3E8A131681D1/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
*Oct 6 14:44:40.550: //119/3E8A131681D1/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 107.137.26.75:5060;rport=56137;branch=z9hG4bK1A20F1
To: <sip:111222333@1.1.1.1>;tag=870a5b262384e4f9f82f59836d699db5.3ee3
CSeq: 101 INVITE
Proxy-Authenticate: Digest realm="sip.flowroute.com", nonce="V/Zqo1f2aXcIo3odEierrGM/0Z+Tu9vp", qop="auth"
Content-Length: 0
*Oct 6 14:44:40.550: //119/3E8A131681D1/CCAPI/cc_api_call_disconnected:
Cause Value=47, Interface=0x234D40CC, Call Id=119
*Oct 6 14:44:40.554: //119/3E8A131681D1/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 101 INVITE
Content-Length: 0
*Oct 6 14:44:40.554: //119/3E8A131681D1/CCAPI/cc_api_call_disconnect_done:
Disposition=-11, Interface=0x234D40CC, Tag=0x0, Call Id=119,
*Oct 6 14:44:40.554: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Oct 6 14:44:40.554: :cc_free_feature_vsa freeing 236B6198
*Oct 6 14:44:40.554: vsacount in free is 1
*Oct 6 14:44:40.554: //118/3E8A131681D1/CCAPI/ccCallReleaseResources:
*Oct 6 14:44:40.554: //118/3E8A131681D1/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
*Oct 6 14:44:40.558: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
*Oct 6 14:44:40.558: //118/3E8A131681D1/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 500 Internal Server Error
To: <sip:+111222333@fl.gg>;tag=19249618-1F31
CSeq: 966322 INVITE
Reason: Q.850;cause=16
Content-Length: 0
*Oct 6 14:44:40.850: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 66
CSeq: 966322 ACK
Content-Length: 0
*Oct 6 14:44:40.854: //118/3E8A131681D1/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x234D40CC, Tag=0x0, Call Id=118,
Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
*Oct 6 14:44:40.854: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Oct 6 14:44:40.854: :cc_free_feature_vsa freeing 236B60B8
*Oct 6 14:44:40.854: vsacount in free is 0
Aseem
