Showing results forĀ
Search instead forĀ
Did you mean:Ā
Forward two different dial numbers at the same time to the same destination
reg_cisco
Level 4
Level 4
Hello everybody,
I need to forward two different dial numbers in the same phone (Cisco 6921) to the same destination.
I'd change the phone if it'll be necessary.
Forward from the end user web is not a valid posibility. It is neccesary to do this forward from the phone.
Any idea, suggestion or testing scenario should be appreciated.
I use CUCM 8.5
Thanks in advance.
Jayanth Velkuri
you can mask the other number by using translation pattern
