04-26-2017 05:39 AM - edited 03-17-2019 10:10 AM
I am forwarding an extension to another extension. The number that is being forwarded is also a DID number. When the call is forwarded, the destination extension only rings one time before going straight to voice mail. How can I extend the number of rings on the destination phone for forwarded calls? I must add that the ring duration on both extensions is set to 20 seconds.
04-26-2017 05:50 AM
I guess its CUCM...Please check "Forward No Answer Timeout" service parameter in CUCM, keep it as default (12 sec) and check, for more info pls check below link.
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-callmanager/12447-forward-no-answer-timeout.html
Suresh
04-26-2017 07:00 AM
Yes, it is CUCM. The "Forward No Answer Timeout" is set to the default of 12. Phone A is forwarding immediately to Phone B, which is what I want. I just want Phone B to ring more than one time before going to voicemail. Phone B rings for 20 seconds when dialed directly but when calls are forwarded to Phone B, there is only one ring before going to voicemail.
