Forwarding a Fax Call
Mark H
Hi everyone,
Looking for some ideas here, perhaps I'm missing something basic! We are trying to forward an incoming fax call to a third party, which is successfully answered but the sending fax device never starts sending the information. Any ideas? Further backstory and information below.
Currently, we receive faxes to an extension (In this example x1000) over ISDN which has a translation pattern to route to a hunt group (Starting on x1500). The extensions in the hunt group all live on a VG248 device with a fax server that PDFs the incoming faxes.
We now wish to use an external provider to receive the faxes. Subsequently, I have attempted to route x1000, using the translation pattern, to the providers number (In this example 0290004000). It successfully answers, starts screaming like a good fax/modem but the sending of the fax never actually occurs.
I'm suspecting the fact we're turning a single call in to a double call leg is causing issues with the sending fax (I.e. it starts handshaking before the receiving end is ready), but I'm unsure where to start and the only other idea I can think of is to have the number forwarded at the Telecom/provider level.
Any ideas?
Mark
Hi Mark.
Wich protocol are you using between CUCM and VOICE gateway?
Can you post the config of your router?
Please let me know
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Carlo,
Thanks for the reply. The gateway is backed out to CUCM using MGCP, the config is below.
Current configuration : 6589 bytes
! No configuration change since last restart
version 12.4
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
hostname BRI-GWY01
boot-start-marker
boot system slot0:c3745-ipvoicek9-mz.124-15.T14.bin
boot system flash:c3745-ipvoicek9-mz.124-9.T7.bin
boot-end-marker
no logging queue-limit
logging buffered 4096 notifications
no logging rate-limit
no logging console
no logging monitor
enable secret 5 ...
aaa new-model
aaa authentication login default local
aaa session-id common
clock timezone GMT+10 10
network-clock-participate slot 1
no network-clock-participate slot 2
network-clock-select 1 E1 1/0
network-clock-select 2 E1 1/1
voice-card 1
no dspfarm
voice-card 2
dspfarm
dsp services dspfarm
ip cef
no ip domain lookup
ip domain name domain.com.au
isdn switch-type primary-net5
application
  global
  service alternate DEFAULT
username .... password 0 ....
archive
log config
  hidekeys
controller E1 1/0
pri-group timeslots 1-10,16 service mgcp
description Brisbane PRI 20-Ch 0732448...
controller E1 1/1
translation-rule 3
Rule 1 ^2 0292962
Rule 2 ^3 0292963
Rule 3 ^4 0396434
Rule 4 ^5 0396435
Rule 5 ^6 0262176
Rule 6 ^7 0892697
translation-rule 2
Rule 1 ^.? 00
translation-rule 1
Rule 0 ^32448000 00292962000
Rule 1 ^32448999 00292963999
Rule 2 ^32448 8
interface Loopback0
ip address 172.26.254.1 255.255.255.255
interface FastEthernet0/0
ip address 10.26.1.5 255.255.0.0
speed 100
full-duplex
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial1/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bind-l3 ccm-manager
isdn bchan-number-order ascending
no cdp enable
interface Serial1/1:15
no ip address
encapsulation hdlc
no cdp enable
ip default-gateway 10.26.1.1
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.26.1.1
no ip http server
no ip http secure-server
ip sla responder
logging trap notifications
logging 172.19.22.159
snmp-server community ...... RO
snmp-server community ...... RW
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps vrrp
snmp-server enable traps tty
snmp-server enable traps xgcp
snmp-server enable traps flash insertion removal
snmp-server enable traps envmon
snmp-server enable traps icsudsu
snmp-server enable traps ds0-busyout
snmp-server enable traps ds1-loopback
snmp-server enable traps atm subif
snmp-server enable traps cnpd
snmp-server enable traps config-copy
snmp-server enable traps dial
snmp-server enable traps dsp card-status
snmp-server enable traps entity
snmp-server enable traps frame-relay multilink bundle-mismatch
snmp-server enable traps frame-relay subif
snmp-server enable traps hsrp
snmp-server enable traps ipmulticast
snmp-server enable traps ospf state-change
snmp-server enable traps ospf errors
snmp-server enable traps ospf retransmit
snmp-server enable traps ospf lsa
snmp-server enable traps ospf cisco-specific state-change nssa-trans-change
snmp-server enable traps ospf cisco-specific state-change shamlink interface
snmp-server enable traps ospf cisco-specific state-change shamlink neighbor
snmp-server enable traps ospf cisco-specific errors
snmp-server enable traps ospf cisco-specific retransmit
snmp-server enable traps ospf cisco-specific lsa
snmp-server enable traps pim neighbor-change rp-mapping-change invalid-pim-message
snmp-server enable traps pppoe
snmp-server enable traps cpu threshold
snmp-server enable traps rsvp
snmp-server enable traps ipsla
snmp-server enable traps syslog
snmp-server enable traps l2tun session
snmp-server enable traps vtp
snmp-server enable traps voice poor-qov
snmp-server enable traps dnis
snmp-server host 172.18.23.19 ......
snmp-server host 172.22.22.97 ......
control-plane
voice-port 1/0:15
cptone AU
voice-port 1/1:15
cptone AU
ccm-manager fallback-mgcp
ccm-manager redundant-host 10.19.1.4
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 10.19.1.5
mgcp
mgcp call-agent 10.18.1.4 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp codec g711alaw packetization-period 20
mgcp package-capability rtp-package
mgcp package-capability sst-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp profile default
sccp local FastEthernet0/0
sccp
sccp ccm 10.18.1.4 priority 1
sccp ccm 10.19.1.4 priority 2
dspfarm transcoder maximum sessions 4
dspfarm confbridge maximum sessions 5
dspfarm
dial-peer cor custom
dial-peer voice 1015 pots
preference 1
service mgcpapp
destination-pattern 0T
incoming called-number .
direct-inward-dial
dial-peer voice 1115 pots
preference 2
service mgcpapp
direct-inward-dial
dial-peer voice 1000 pots
preference 1
destination-pattern [234567]...
translate-outgoing called 3
dial-peer voice 1001 pots
preference 2
call-manager-fallback
secondary-dialtone 0
max-conferences 8 gain -6
transfer-system full-consult
limit-dn 7910 1
limit-dn 7935 1
limit-dn 7940 1
limit-dn 7960 1
ip source-address 10.26.1.5 port 2000
max-ephones 200
max-dn 244
dialplan-pattern 1 32448... extension-length 4
transfer-pattern 2...
transfer-pattern 3...
transfer-pattern 4...
transfer-pattern 5...
transfer-pattern 6...
transfer-pattern 7...
keepalive 20
default-destination 2000
alias 1 8... to 2000
call-forward busy 3000
call-forward noan 3000 timeout 12
moh MOH20110413.ulaw.wav
multicast moh 239.1.1.1 port 16400 route 10.26.1.5 172.26.254.1
time-format 24
date-format dd-mm-yy
line con 0
speed 115200
line aux 0
line vty 0 4
password .....
ntp clock-period 17180777
ntp source FastEthernet0/0
ntp peer 172.18.15.34
end
