FXO port calls not going through via LCR (leased cost routing)
abc4308449
Morning, Charles
I have another problem I have 2x 4 port FXO cards at one brach all configures are listed below, but when a call is being made via the FXO port listed below calls are not going through I have done all possible traces but with no luck, Please can you help?
Call Manger is : 10.144.56.10
2900 Gateway router is: 10.248.34.102
Show Voice Port Summary:
0/1/0           --  fxo-ls      up    dorm idle     on-hook  y
0/1/1           --  fxo-ls      up    dorm idle     on-hook  y
0/1/2           --  fxo-ls      up    dorm idle     on-hook  y
0/1/3           --  fxo-ls      up    dorm idle     on-hook  y
0/2/0           --  fxo-ls      up    dorm idle     on-hook  y
0/2/1           --  fxo-ls      up    dorm idle     on-hook  y
0/2/2           --  fxo-ls      up    dorm idle     on-hook  y
0/2/3           --  fxo-ls      up    dorm idle     on-hook  y
Below is the routers configure:
isdn switch-type primary-net5
cts logging verbose
voice-card 0
 dspfarm
 dsp services dspfarm
voice call send-alert
voice call convert-discpi-to-prog always
voice rtp send-recv
voice disc-pi-incoming-on
voice service voip
 ip address trusted list
  ipv4 10.149.250.0 255.255.255.0
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 supplementary-service h450.12
 no supplementary-service sip refer
 redirect ip2ip
 fax protocol pass-through g711alaw
 modem passthrough nse codec g711alaw
 h323
  call preserve limit-media-detection
 sip
  session transport tcp
  registrar server expires max 600 min 60
voice class codec 1
 codec preference 1 g729r8
 codec preference 2 g711ulaw
voice class h323 1
  h225 timeout tcp establish 3
voice register global
 mode srst
 timeouts interdigit 5
 system message SRST Mode - Limited
 max-dn 100
 max-pool 110
voice register pool  1
 id network 10.149.250.0 mask 255.255.255.0
 preference 1
 proxy 10.248.34.102
 dtmf-relay rtp-nte cisco-rtp sip-notify
 codec g711ulaw
 no vad
voice translation-rule 1
 rule 1 /^04850024$/ /82995927/
 rule 2 /^.*\(....\)/ /8198\1/
voice translation-rule 2
 rule 1 /^8198\(4...\)$/ /04850024\1/
voice translation-rule 3
 rule 1 /^4...$/ /8198\0/
 rule 2 /^7...$/ /8198\0/
 rule 3 /^5927$/ /8299\0/
voice translation-profile phones-in
 translate called 3
voice translation-profile pstn-in
 translate called 1
voice translation-profile pstn-out
 translate calling 2
license udi pid CISCO2921/K9 sn FCZ182370YT
hw-module pvdm 0/0
hw-module pvdm 0/1
username a privilege 15 password 7 0305
username btsupport password 7 04591F151A315C411B0D44
redundancy
controller E1 0/0/0
 framing NO-CRC4
 pri-group timeslots 1-31 service mgcp
 description PSTN +263 (0)4850024 4000 - 4999
controller E1 0/0/1
 shutdown
 description SPARE - NOT USED
ip ftp source-interface Loopback10
ip tftp source-interface Loopback10
ip ssh time-out 60
ip ssh source-interface Loopback10
ip ssh version 2
 description Management and Routing Loopback
 ip address 10.248.34.102 255.255.255.255
 h323-gateway voip interface
 h323-gateway voip bind srcaddr 10.248.34.102
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description Zimbabwe, ZW0001 - Harare LAN switch port 23 (VLAN30)[BTM]
 ip address 10.149.250.2 255.255.255.0
 no ip redirects
 no ip unreachables
 duplex auto
 speed auto
 no mop enabled
interface GigabitEthernet0/1
 no ip address
 no ip redirects
 no ip unreachables
 shutdown
 duplex auto
 speed auto
 no mop enabled
interface GigabitEthernet0/2
 no ip address
 no ip redirects
 no ip unreachables
 shutdown
 duplex auto
 speed auto
 no mop enabled
interface Serial0/0/0:15
 no ip address
 encapsulation hdlc
 no snmp trap link-status
 isdn overlap-receiving
 isdn incoming-voice voice
 isdn bind-l3 ccm-manager
 isdn sending-complete
 no cdp enable
router ospf 1
 router-id 10.248.34.102
 network 10.149.250.0 0.0.0.255 area 0
 network 10.248.34.102 0.0.0.0 area 0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tacacs source-interface Loopback10
logging source-interface Loopback10
logging host 195.218.44.198
logging host 194.102.0.149
snmp-server community m0R3te4V1cAr RW 15
snmp-server community go1Ngf0Rg0lD RO 15
snmp-server trap-source Loopback10
snmp-server tftp-server-list 15
snmp-server location Zimbabwe - ZW0001 - Harare
snmp-server enable traps snmp linkdown linkup coldstart warmstart
snmp-server enable traps envmon fan shutdown supply temperature status
snmp-server enable traps config
snmp-server enable traps entity
snmp-server host 172.27.8.36 version 2c aaza-vg-zw0001-01
snmp-server host 172.27.8.37 version 2c aaza-vg-zw0001-01
snmp-server host 172.27.8.43 version 2c aaza-vg-zw0001-01
snmp-server host 172.27.8.44 version 2c aaza-vg-zw0001-01
snmp-server file-transfer access-group 15 protocol tftp
tacacs-server host 199.80.49.10
tacacs-server host 199.80.48.10
tacacs-server timeout 20
tacacs-server directed-request
tacacs-server key 7 06070E74141C5A
access-list 6 deny   any
access-list 7 deny   any
access-list 15 remark ++ Allowed SNMP BT only++
access-list 15 permit 62.239.34.0 0.0.1.255
access-list 15 permit 194.102.6.0 0.0.0.255
access-list 15 permit 194.102.8.0 0.0.1.255
access-list 15 permit 194.102.19.0 0.0.0.255
access-list 15 permit 193.113.254.128 0.0.0.127
access-list 15 permit 193.113.244.128 0.0.0.127
access-list 15 permit 172.27.8.32 0.0.0.31
access-list 99 permit 10.144.0.124
control-plane
voice-port 0/0/0:15
 cptone C1
 bearer-cap Speech
voice-port 0/1/0
 cptone C1
 timing hookflash-out 50
 timing guard-out 1000
 description LCR to Mobile (SIM 0772238762)
voice-port 0/1/1
 cptone C1
 description LCR to Mobile (SIM 0772100078)
voice-port 0/1/2
 cptone C1
 description LCR to Mobile (SIM 0772105366 Flty)
voice-port 0/1/3
 cptone C1
voice-port 0/2/0
 cptone C1
voice-port 0/2/1
 cptone C1
 description LCR to Mobile (SIM 0772238763)
voice-port 0/2/2
 cptone C1
 description LCR to Mobile (SIM 0772105370)
voice-port 0/2/3
mgcp
mgcp call-agent 10.144.56.10 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface Loopback10
mgcp bind media source-interface Loopback10
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sccp local Loopback10
sccp ccm 10.144.56.10 identifier 1 version 7.0
sccp ccm 10.144.56.5 identifier 2 version 7.0
sccp
sccp ccm group 1
 associate ccm 1 priority 1
 associate ccm 2 priority 2
 associate profile 1 register XCO-HW-ZW0001
 associate profile 2 register CFB-HW-ZW0001
 associate profile 3 register MTP-HW-ZW0001
 keepalive retries 5
 switchover method immediate
 switchback method immediate
 switchback interval 15
ccm-manager music-on-hold
ccm-manager fallback-mgcp
ccm-manager redundant-host 10.144.56.5
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager config server 10.144.56.4 10.144.56.8
ccm-manager config
ccm-manager download-tones
dspfarm profile 1 transcode
 codec g729abr8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 codec g729r8
 maximum sessions 10
 associate application SCCP
dspfarm profile 2 conference
 codec g729br8
 codec g729r8
 codec g729abr8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 maximum sessions 1
dspfarm profile 3 mtp
 codec g711ulaw
 maximum sessions software 250
dial-peer voice 1 pots
 description PSTN outbound
 translation-profile incoming pstn-in
 translation-profile outgoing pstn-out
 destination-pattern 0T
 incoming called-number .
 direct-inward-dial
 port 0/0/0:15
 forward-digits all
dial-peer voice 100 pots
 description Emergency outbound
 destination-pattern 1..
 port 0/0/0:15
 forward-digits all
dial-peer voice 900 pots
 description Emergency and Services outbound
 destination-pattern 9..
 port 0/0/0:15
 forward-digits all
dial-peer voice 11 pots
 preference 1
 service mgcpapp
 destination-pattern 07[1378]T
 port 0/1/0
 forward-digits all
dial-peer voice 12 pots
 preference 2
 service mgcpapp
 port 0/1/1
 forward-digits all
dial-peer voice 13 pots
 preference 3
 service mgcpapp
 port 0/1/2
 forward-digits all
dial-peer voice 14 pots
 preference 4
 service mgcpapp
 port 0/2/0
 forward-digits all
dial-peer voice 15 pots
 preference 5
 service mgcpapp
 port 0/2/1
 forward-digits all
dial-peer voice 16 pots
 preference 6
 service mgcpapp
 port 0/2/2
 forward-digits all
dial-peer voice 21 pots
 preference 1
 service mgcpapp
 destination-pattern 086T
 port 0/1/0
 forward-digits all
dial-peer voice 22 pots
 preference 2
 service mgcpapp
 port 0/1/1
 forward-digits all
dial-peer voice 23 pots
 preference 3
 service mgcpapp
 port 0/1/2
 forward-digits all
dial-peer voice 24 pots
 preference 4
 service mgcpapp
 port 0/2/0
 forward-digits all
dial-peer voice 25 pots
 preference 5
 service mgcpapp
 port 0/2/1
 forward-digits all
dial-peer voice 26 pots
 preference 6
 service mgcpapp
 port 0/2/2
 forward-digits all
dial-peer voice 99901990 pots
 service mgcpapp
 port 0/1/0
dial-peer voice 99901991 pots
 service mgcpapp
 port 0/1/1
dial-peer voice 99901992 pots
 service mgcpapp
 port 0/1/2
dial-peer voice 99902990 pots
 service mgcpapp
 port 0/2/0
dial-peer voice 99902991 pots
 service mgcpapp
 port 0/2/1
dial-peer voice 99902992 pots
 service mgcpapp
 port 0/2/2
dial-peer voice 99901099 pots
 service mgcpapp
 port 0/1/0
dial-peer voice 99901199 pots
 service mgcpapp
 port 0/1/1
dial-peer voice 99901299 pots
 service mgcpapp
 port 0/1/2
dial-peer voice 99902099 pots
 service mgcpapp
 port 0/2/0
dial-peer voice 99902199 pots
 service mgcpapp
 port 0/2/1
dial-peer voice 99902299 pots
 service mgcpapp
 port 0/2/2
dial-peer voice 99901993 pots
 service mgcpapp
 port 0/1/3
dial-peer voice 66 pots
 preference 4
 service mgcpapp
 port 0/1/3
 forward-digits all
dial-peer voice 99901399 pots
 service mgcpapp
 port 0/1/3
sip-ua
 registrar ipv4:10.248.34.102 expires 600
gatekeeper
 shutdown
call-manager-fallback
 max-conferences 8 gain -6
 transfer-system full-consult
 timeouts interdigit 6
 ip source-address 10.248.34.102 port 2000
 max-ephones 100
 max-dn 100 dual-line
 system message primary Link Down Limited Functionality
 transfer-pattern .T
 transfer-pattern 8198....
 keepalive 10
 translation-profile incoming phones-in
 moh enable-g711 "SampleAudioSource.ulaw.wav"
 multicast moh 239.1.1.3 port 16384 route 10.149.250.2 10.248.34.102
 date-format dd-mm-yy
banner exec ^C
        If you are not authorised to access this device then
                          Please log off now.
*** ALL Commands from this device are Authorised Authenticated & Accounted ***
^C
banner login ^C
British Telecommunications plc
WARNING: You have accessed a network device operated by BT. You are required
to have a personal authorisation from the system administrator before you use
this computer and you are strictly limited to the use set out in that written authorisation.
Unauthorised access to or misuse of this system is prohibited
and may constitute an offence under the Computer Misuse Act 1990.
If you disclose any information obtained through this system without authority
BT will take appropriate action against you. This may include legal
proceedings, prosecution and disciplinary action up to and including
dismissal.
^C
line con 0
 exec-timeout 15 0
 password 7 00060715114B1B091D35
 logging synchronous
line aux 0
 no exec
 transport output none
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 exec-timeout 15 0
 password 7 0509121C345C5E060B11
 logging synchronous
 transport preferred ssh
 transport input telnet ssh
 transport output telnet ssh
line vty 5 15
 exec-timeout 15 0
 logging synchronous
scheduler allocate 20000 1000
ntp source Loopback10
ntp update-calendar
ntp server 199.80.49.161
ntp server 199.80.49.170 prefer
end
Edwin
 you use a MGCP protocol to both of your FXO configuration, in other words, your should configure your FXO in your Call Control - CUCM (IP Addr 10.144.56.10).
 Did you configure both FXOs in your CUCM?
Hope this helps.
All FXO ports a registered with the call manager, problem is when I plugin my analogue phone to the LCR i get a dial tone but when I plugin my LCR to the FXO port I hear nothing, dead!
" you use a MGCP protocol to both of your FXO configuration, in other words, your should configure your FXO in your Call Control - CUCM (IP Addr 10.144.56.10)"
Meaning? can you please provide me with the step-by-step process to follow please.
 when you configured the FXO in CUCM, you did that in CUCM Administration > Device > Gateway > <select the GW model> > choose MGCP > select the Module/Sub-Unit.
 What Port-Type did you select? Ground Start or Loop Start?
Regards.
loop Start is the port i choose i ahve also tried to change it to ground start still calls are not going out through the LCR
