ISR3845 (FXO)--> MGCP --> CUCM 12.5
Hi All, i am getting FXOGS_PARK for my VPM STATE on FXO port.
Once i do a shut & no shut on the voice port, bogus incoming call like a ringback comes in, but when i answer, it is just a busy tone.
GJ-3845(config)#voice-port 0/2/0
GJ-3845(config-voiceport)#shut
GJ-3845(config-voiceport)#on
Jan 4 13:16:44.991: htsp_process_event: [0/2/0, FXOGS_PARK, E_HTSP_IF_OOS]htspm_mgt_state
Jan 4 13:16:44.991: htsp_timer_stop
Jan 4 13:16:44.991: htsp_timer_stop2
Jan 4 13:16:44.991: htsp_timer_stop3
Jan 4 13:16:44.991: htsp_timer_stop_mlpp
Jan 4 13:16:44.991: htsp_process_event: [0/2/0, S_OPEN_PEND, E_DSP_INTERFACE_INFO]
Jan 4 13:16:45.495: htsp_process_event: [0/2/0, S_DOWN, E_DSP_SIG_0100]
GJ-3845(config-voiceport)#no shut
Jan 4 13:16:52.931: htsp_process_event: [0/2/0, S_DOWN, E_HTSP_IF_INSERVICE]
Jan 4 13:16:52.931: %LINK-3-UPDOWN: Interface Foreign Exchange Office 0/2/0, changed state to up
Jan 4 13:16:52.931: Foreign Exchange Office 0/2/0 rx_signal_map:
0 F F F
5 F F F
F F F F
F F F F
Jan 4 13:16:52.931: [0/2/0] set signal state = 0x4 timestamp = 0
Jan 4 13:16:52.931: Foreign Exchange Office 0/2/0 tx_signal_map:
0 0 0 0
4 4 6 4
8 8 8 8
C C C C
Jan 4 13:16:52.931: htsp_process_event: [0/2/0, S_OPEN_PEND, E_HTSP_GO_UP]
Jan 4 13:16:53.043: htsp_process_event: [0/2/0, FXOGS_NULL, E_HTSP_INIT]fxogs_null_init
Jan 4 13:16:53.043: [0/2/0] set signal state = 0x4 timestamp = 0
Jan 4 13:16:53.043: htsp_process_event: [0/2/0, FXOGS_INIT, E_HTSP_INSERVE]fxogs_init_inserve
Jan 4 13:16:53.043: htsp_process_event: [0/2/0, FXOGS_ONHOOK, E_DSP_SIG_0100]fxogs_onhook_tip_ground
Jan 4 13:16:53.043: htsp_timer - 7000 msec
Jan 4 13:16:53.043: htsp_process_event: [0/2/0, FXOGS_TIP_GROUND, E_DSP_SIG_0100]
Jan 4 13:16:53.043: fxogs_stop_disc_timer
Jan 4 13:16:53.043: htsp_timer_stop2
Jan 4 13:17:00.043: htsp_process_event: [0/2/0, FXOGS_TIP_GROUND, E_HTSP_EVENT_TIMER]fxogs_tip_ground_timeouthtsp_setup_ind
Jan 4 13:17:00.043: [0/2/0] get_fxo_caller_id:Caller ID received. Message type=4 length=18 checksum=E1
Jan 4 13:17:00.043: [0/2/0] Caller ID String 04 0F 30 38 31 38 31 32 31 38 37 32 32 33 37 33 37 E1
Jan 4 13:17:00.043: [0/2/0] get_fxo_caller_id calling num=7223737 calling name= calling time=08/18 12:18
Jan 4 13:17:00.043: [0/2/0] set signal state = 0xC timestamp = 0
Jan 4 13:17:00.043: htsp_process_event: [0/2/0, FXOGS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]
Jan 4 13:17:00.043: fxogs_wait_setup_ack:
Jan 4 13:17:00.043: htsp_process_event: [0/2/0, FXOGS_OFFHOOK, E_HTSP_SETUP_ACK]
Jan 4 13:17:00.043: htsp_process_event: [0/2/0, FXOGS_OFFHOOK, E_HTSP_CONNECT]fxogs_proc_voice
Jan 4 13:17:00.051: htsp_process_event: [0/2/0, FXOGS_OFFHOOK, E_HTSP_VOICE_CUT_THROUGH]
Jan 4 13:17:00.051: htsp_call_bridged invoked
GJ-3845#show voice call summary
PORT CODEC VAD VTSP STATE VPM STATE
0/2/0 - - - FXOGS_PARK
0/2/1 - - - FXOGS_ONHOOK
0/2/2 - - - FXOLS_ONHOOK
0/2/3 - - - FXOLS_ONHOOK
0/3/0 - - - FXOLS_ONHOOK
0/3/1 - - - FXOLS_ONHOOK
I am able to make incoming call, but outgoing call does not work.
Is there any changes i need to make on my side?
voice-port 0/2/0
supervisory disconnect dualtone mid-call
supervisory custom-cptone DST
supervisory dualtone-detect-params 1
no battery-reversal
signal groundStart
cptone SG
timeouts call-disconnect 3
timeouts wait-release 3
timing hookflash-out 100
timing guard-out 1000
caller-id enable
