FXO problem
habouzyad
I have a CallManager 4.3 and Cisco 2811 configured in H323 Voice gateway. I added two new FXO card connected to an equipment (Fixed Wireless Terminal for GSM Mobile Networks : Ericsson G30/G35).
This the configuration for the port FXO :
voice-port 0/0/0
no battery-reversal
compand-type a-law
cptone FR
timeouts interdigit 5
connection plar opx 9416
impedance complex2
and the dial-peer :
dial-peer voice 6 pots
destination-pattern 6T
progress_ind alert enable 8
direct-inward-dial
port 0/0/0
forward-digits 9
I have two problems :
1- when we make a call to the GSM Number :
the user in gsm have a good quality ( speaking and listening)
the user in cisco iphone listen bad quality ( like a user is very far [ weak sound])
2- when the called user end the call , the counters in the iphone still working??
Please could someone help me and suggest me a solution
Thanks in advance
Best Regards
Hicham
ivillegas
Level 6
Level 6
What model of IP phone do you have and what phone load are they running?
Which Codec are you using?
mcheatle
Try setting your impedance complex5
