FXO with pulse dialling
In Kiev, Ukraine.
I have 4 analogue lines connected on a 4 port FXO card. When connected to the Siemens PABX, all lines can call anywhere. When I connect the lines one by one to the same port on the gateway with the same configuration, I have only 1 line being able to make only local calls. I plug those lines 1 by one on an analog phone, with the setting to pulse, then all of them can also call anywhere. It does not make sense that I use the same port for testing via the CCM, and only 1 can dial and only local.
Any advice.
Steven Holl
Can you get these debugs for a failure, so we can physically see why the second call fails?
debug voip ccpai inout
debug vpm sig
Also include:
sh run
sh voice call sum
