05-28-2008 01:44 AM - edited 03-15-2019 10:55 AM
We have connected a Public Address System to a FXS Network Module (NM-HDA) with the following configuration:
voice-port 1/0/X
disconnect-ack
disc_pi_off
cptone ES
timeouts call-disconnect 5
timeouts wait-release 5
Anyway, the port continues busy after 20 seconds of disconnecting the call. Is this normal? Any idea?
06-03-2008 06:25 AM
If you are using the MGCP gateway, when the IP phone hangs up, after 15-20 seconds, you will get a busy tone on the FXS port. If you put in the command timeout call-disconnect 5 under the FXS voice port. The MGCP control port will not provide a busy tone until after 15-20 seconds after the IP phone hang up. If you change it to H323, the command will take effect.
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800ae2d1.shtml
06-03-2008 06:57 AM
The gateway is already in H.323. Thanks anyway...
