FXS pot dial peer and delay in calling out
hmalekib
I have an issue in reducing the delay in dialing out from a analog phone/ PBX. The only work around I found is by reducing the interdigit timer but I rather setup the dial peers properly so they route the outgoing calls quickly when 9 and 10 digits is dialed.
Here is my config so far:
voice class e164-pattern-map 1
 description E164 Pattern Map for calling numbers
  e164 911
  e164 1[2-9]..[2-9]......
  e164 9[^1]T
  e164 [2-9]..[2-9]......
voice class dpg 111
 description - Line 2
 dial-peer 11 preference 1
dial-peer voice 11 voip
 description Line 2: PSTN to SIP (Outgoing to Provider)
 session protocol sipv2
 session target dns:sip5.provider.net:5060
 session transport udp
 destination e164-pattern-map 1
 voice-class codec 101
 voice-class sip profiles 11
 dtmf-relay rtp-nte h245-alphanumeric
 fax-relay ecm disable
 fax rate 14400
 fax nsf 000000
 no vad
 authentication username 07191002 password 7 XXXXXXXXX realm sip5.provider.net
dial-peer voice 111 pots
 description Line 2
 destination-pattern 07191002
 destination dpg 111
 port 0/1/1
FYI I'm using a 2900 series router with VIC3-4FXS/DID card. This is connected to the provider's SIP trunk.
There is still a 10 second delay from the time you dial the number until it calls out.
Any help will be great.
jonathan.salter
Level 3
Level 3
Put a $ in the pattern map...that should work
Here is my example:
voice class e164-pattern-map 2
  e164 9011T
  e164 91[2-9]..[2-9]......$
  e164 9[2-9]..[2-9]......$
Please remember to rate useful posts, click on the stars below.
