gatekeeper H.323 socket error
alex goshtaei
Hi All,
we have two GKs communicate over H.225. Call setup is successful and two endpoints communicate with each other, each one behind one GK. after about 10-15 min, call is dropped. after run debug in GK, I see following error message. if you have any suggestion, I'd very appreciate to share it.
"H323 has received a socket error indication with error code Socket Closed"
thanks
Alex
Hi Alex,
Establish a call between endpoints, then enable debu h225 asn1 on both endpoints. Share the output of the debugs after the call disconnect.
You may also want to enable ip tcp transaction debug..
So you should do this
debug h225 asn1
debug ip tcp transaction
Please rate useful posts
"For the love of God is broader than the measure of man's mind And the heart of the Eternal is most wonderfully kind"
Please rate all useful posts
