11-11-2008 01:46 AM - edited 03-15-2019 02:28 PM
I has a roll out whereby we will implement a single gatekeeper for IP/ E164 address resolution. Each remote site/ Cluster has a single site code e.g 712, 789, 734 etc used for both Voice and Video. Would you register two Gatekeeeper controlled trunks 1 x Voice , 1 x Video so you can have separate Tech-Preifx so we have different bandwidth control, codec etc for Voice and Video? thanks
11-24-2008 04:16 AM
Any replies? Can I register two x GK trunks to the GK from the same CUCM 0 1 x Voice tech prefix 1#. 1 x video tech prefix 2#- what is the best way, I don`t really want different access codes
many thanks
11-24-2008 04:42 AM
Some more info
I have a roll out soon with Gatekeeper involvement. Each of our sites use a site code to call each other at the moment it is purely voice however with Video we would like to maintain the same access, site codes but use Tech Prefix to distinguish between Voice and Video so we have different codecs , bandwidth for voice and video. Is it possible to register two gatekeeper trunks to the same Gatekeeper form the same CUCM
tech prefix x1# Voice
tech prefix 2# Video
At the moment the routing is based upon Zone prefix`s however with video being a different tech prefix how does it work ?
Site one
Site two
Zone prefix 123 site one
zone prefix 125 site two
Ideally the bandwidth control will be different for the two preifx`s - Voice , Video but the site codes are the same
Would you now cerate zone prefix`s to include the Tech Prefix or perhaps highlight and use the video prefix only to select the next hop ? We would use zone prefix to route to the other sites do you need to create two zone prefix for each of the tech prefix zone- do tech prefix play part in the zone prefix or do you use "hop off" to them ?
Zone prefix 1#123 site one
Zone prefix 2#123 site one
Zone prefix 1#125 site two
Zone prefix 2#'125 site two
gw-type-prefix 2# hopoff site two
or do we use tech-prefix hop off so to route to site two but assign different codec
many thanks
