Gateway - Gatekeeper registration issue
AlanJamesNet5
Hey All,
I'm having some issues with registering a gateway to a gatekeeper.
I did a "debug debug h225 asn1 " on the the gatekeeper, i saw the request messages being received. But I didn't see any reject messages.
Once thing I did notice on the gatekeeper if i did a
debug ras
I get the below message
Jan 17 09:45:59.465:  IPSOCK_RAS_sendto:   msg length 45 from 192.168.254.40:1719 to 192.168.173.1: 55861
192.168.254.40 is a loopback address on the gatekeeper, my gateway is trying to register to 192.168.254.5 as below.
h323-gateway voip id KEST_CHPP_GK1 ipaddr 192.168.254.5 1718
Should the reply from my gatekeeper RAS be from 192.168.254.5?
Any suggestions how i can further trouble shoot the end point registration if there are no reject messages ?
Many Thanks
DaveX4285_2
Can you post the relevant Configuration from the gatekeeper. Possibly the h323 gateway?
Hey there, thanks for the reply
I've just pasted the config relevant to the site, we have another gatekeeper that works fine with this configuration, but i'm migrating to a new router 3945 - 15.1(4)M2, and the end points wont register to this new gatekeeper.
interface GigabitEthernet0/0.20
description *** VOIP ***
encapsulation dot1Q 20
ip address 192.168.173.1 255.255.255.192
h323-gateway voip interface
h323-gateway voip h323-id KEST_CHPP_CCME@TEST.com.au
h323-gateway voip tech-prefix 1#
h323-gateway voip bind srcaddr 192.168.173.1
end
gatekeeper
zone local KEST_CHPP_GK1 TEST.com.au
bandwidth total zone KEST_CHPP_GK1 128
gw-type-prefix 1#* default-technology
arq reject-unknown-prefix
zone prefix KEST_CHPP_GK1 226.
no shutdown
SR_3945#show gatekeeper status
    Gatekeeper State: UP
    Zone Name:        KEST_CHPP_GK1
Alan
AlanJamesNet5
ok i think my orginally direction was correct
the output from the orginal debug ras command
(192.168.254.40 is the loop back of the router)
I changed the following on the gatekeeper
zone local KEST_CHPP_GK1 test.com.au 192.168.254.5 (specified the ras address)
new debug ras
Jan 18 00:41:40.573:  IPSOCK_RAS_sendto:   msg length 82 from 192.168.254.5:1719 to 192.168.173.1: 55861
So, my question is how to define the ras address globally ? As I have not done this on the other gatekeeper.
Thanks again,
Alan
