German menu language on 7960G SIP Phone
Heiko Kelling
Hi All
I have flashed a 7960G SCCP Phone to SIP Firmware.
Is there any possibility to give this phone another menu language, like german?
Or is this running only on SCCP Firmware?
Thank you
Brandon Pierce
Level 4
Level 4
You need locales for this.  See the following links.
https://supportforums.cisco.com/discussion/11485856/change-cucm-85-default-language-8941
http://docwiki.cisco.com/wiki/Cucm-phone-locale-installers
thank you for the help.
Now I have these files in my TFTP Server.
These are my files:
OS79XX.TXT
P0S3-08-12-00
SEP0014A8924D6D.CNF.XML
<device>
<devicePool>
<callManagerGroup>
<members>
<member priority="0">
<callManager>
<ports>
<ethernetPhonePort>2000</ethernetPhonePort>
</ports>
<processNodeName> </processNodeName>
</callManager>
</member>
</members>
</callManagerGroup>
</devicePool>
<versionStamp>{Jan 01 2005 00:00:00}</versionStamp>
<loadInformation>P0S3-08-12-00</loadInformation>
<userLocale>
<name>German_Germany</name>
<langCode>de</langCode>
</userLocale>
<networkLocale>Germany</networkLocale>
<idleTimeout>0</idleTimeout>
<authenticationURL></authenticationURL>
<directoryURL></directoryURL>
<idleURL></idleURL>
<informationURL></informationURL>
<messagesURL></messagesURL>
<proxyServerURL></proxyServerURL>
<servicesURL></servicesURL>
</device>
SIP0014A8924D6D.cnf
# SIP Configuration Generic File
# Line 1 appearance
line1_name: 01010101001
# Line 1 Registration Authentication
line1_authname: "UNPROVISIONED"
# Line 1 Registration Password
line1_password: "UNPROVISIONED"
# Line 2 appearance
line2_name: football
# Line 2 Registration Authentication
line2_authname: "UNPROVISIONED"
# Line 2 Registration Password
line2_password: "UNPROVISIONED"
####### New Parameters added in Release 2.0 #######
# All user_parameters have been removed
# Phone Label (Text desired to be displayed in upper right corner)
phone_label: ""	; Has no effect on SIP messaging
# Line 1 Display Name (Display name to use for SIP messaging)
line1_displayname: "User ID"
# Line 2 Display Name (Display name to use for SIP messaging)
line2_displayname: ""
####### New Parameters added in Release 3.0 ######
# Phone Prompt (The prompt that will be displayed on console and telnet)
phone_prompt:   "SIP Phone"      ; Limited to 15 characters (Default - SIP Phone)
# Phone Password (Password to be used for console or telnet login)
phone_password: "cisco" ; Limited to 31 characters (Default - cisco)
# User classifcation used when Registering [ none(default), phone, ip ]
user_info: none
SIPDefault.cnf
# SIP Default Generic Configuration File
# Image Version
image_version: P0S381200
language: german
# Proxy Server
proxy1_address: ""		; Can be dotted IP or FQDN
proxy2_address: ""		; Can be dotted IP or FQDN
proxy3_address: ""		; Can be dotted IP or FQDN
proxy4_address: ""		; Can be dotted IP or FQDN
proxy5_address: ""		; Can be dotted IP or FQDN
proxy6_address: ""		; Can be dotted IP or FQDN
# Proxy Server Port (default - 5060)
proxy1_port: 5060
proxy2_port: 5060
proxy3_port: 5060
proxy4_port: 5060
proxy5_port: 5060
proxy6_port: 5060
# Proxy Registration (0-disable (default), 1-enable)
proxy_register: 0
# Phone Registration Expiration [1-3932100 sec] (Default - 3600)
timer_register_expires: 3600
# Codec for media stream (g711ulaw (default), g711alaw, g729a)
preferred_codec: g711ulaw
# TOS bits in media stream [0-5] (Default - 5)
tos_media: 5
# Inband DTMF Settings (0-disable, 1-enable (default))
dtmf_inband: 1
# Out of band DTMF Settings (none-disable, avt-avt enable (default), avt_always - always avt )
dtmf_outofband: avt
# DTMF dB Level Settings (1-6dB down, 2-3db down, 3-nominal (default), 4-3db up, 5-6dB up)
dtmf_db_level: 3
# SIP Timers
timer_t1: 500 			; Default 500 msec
timer_t2: 4000 			; Default 4 sec
sip_retx: 10			; Default 10
sip_invite_retx: 6 		; Default 6
timer_invite_expires: 180 	; Default 180 sec
# Dialplan template (.xml format file relative to the TFTP root directory)
dial_template: dialplan
# TFTP Phone Specific Configuration File Directory
tftp_cfg_dir: ""		; Example:  ./sip_phone/
# Time Server (There are multiple values and configurations refer to Admin Guide for Specifics)
sntp_server: ""			; SNTP Server IP Address
sntp_mode: directedbroadcast	; unicast, multicast, anycast, or directedbroadcast (default)
time_zone: EST			; Time Zone Phone is in
dst_offset: 1			; Offset from Phone's time when DST is in effect
dst_start_month: April		; Month in which DST starts
dst_start_day: ""		; Day of month in which DST starts
dst_start_day_of_week: Sun	; Day of week in which DST starts
dst_start_week_of_month: 1	; Week of month in which DST starts
dst_start_time: 02		; Time of day in which DST starts
dst_stop_month: Oct		; Month in which DST stops
dst_stop_day: ""		; Day of month in which DST stops
dst_stop_day_of_week: Sunday	; Day of week in which DST stops
dst_stop_week_of_month: 8	; Week of month in which DST stops 8=last week of month
dst_stop_time: 2		; Time of day in which DST stops
dst_auto_adjust: 1		; Enable(1-Default)/Disable(0) DST automatic adjustment
time_format_24hr: 1		; Enable(1 - 24Hr Default)/Disable(0 - 12Hr)
# Do Not Disturb Control (0-off, 1-on, 2-off with no user control, 3-on with no user control)
dnd_control: 0			; Default 0 (Do Not Disturb feature is off)
# Caller ID Blocking (0-disbaled, 1-enabled, 2-disabled no user control, 3-enabled no user control)
callerid_blocking: 0		; Default 0 (Disable sending all calls as anonymous)
# Anonymous Call Blocking (0-disabled, 1-enabled, 2-disabled no user control, 3-enabled no user control)
anonymous_call_block: 0		; Default 0 (Disable blocking of anonymous calls)
# DTMF AVT Payload (Dynamic payload range for AVT tones - 96-127)
dtmf_avt_payload: 101		; Default 101
# Sync value of the phone used for remote reset
sync: 1				; Default 1
####### New Parameters added in Release 2.1 #######
# Backup Proxy Support
proxy_backup: ""		; Dotted IP of Backup Proxy
proxy_backup_port: 5060		; Backup Proxy port (default is 5060)
# Emergency Proxy Support
proxy_emergency: "" 		; Dotted IP of Emergency Proxy
proxy_emergency_port: 5060	; Emergency Proxy port (default is 5060)
# Configurable VAD option
enable_vad: 0			; VAD setting 0-disable (Default), 1-enable
####### New Parameters added in Release 2.2 ######
# NAT/Firewall Traversal
nat_enable: 0                   ; 0-Disabled (default), 1-Enabled
nat_address: ""		        ; WAN IP address of NAT box (dotted IP or DNS A record only)
voip_control_port: 5060      	; UDP port used for SIP messages (default - 5060)
start_media_port: 16384 	; Start RTP range for media (default - 16384)
end_media_port: 32766   	; End RTP range for media (default - 32766)
nat_received_processing: 0	; 0-Disabled (default), 1-Enabled
# Outbound Proxy Support
outbound_proxy: ""	 	; restricted to dotted IP or DNS A record only
outbound_proxy_port: 5060       ; default is 5060
####### New Parameter added in Release 3.0 #######
# Allow for the bridge on a 3way call to join remaining parties upon hangup
cnf_join_enable : 1		; 0-Disabled, 1-Enabled (default)
####### New Parameters added in Release 3.1 #######
# Allow Transfer to be completed while target phone is still ringing
semi_attended_transfer: 1	; 0-Disabled, 1-Enabled (default)
# Telnet Level (enable or disable the ability to telnet into the phone)
telnet_level: 1			; 0-Disabled (default), 1-Enabled, 2-Privileged
####### New Parameters added in Release 4.0 #######
# XML URLs
services_url: ""		; URL for external Phone Services
directory_url: ""		; URL for external Directory location
logo_url: ""			; URL for branding logo to be used on phone display
# HTTP Proxy Support
http_proxy_addr: ""		; Address of HTTP Proxy server
http_proxy_port: 80		; Port of HTTP Proxy Server (80-default)
# Dynamic DNS/TFTP Support
dyn_dns_addr_1: ""              ; restricted to dotted IP
dyn_dns_addr_2: ""              ; restricted to dotted IP
dyn_tftp_addr: ""               ; restricted to dotted IP
# Remote Party ID
remote_party_id: 0		; 0-Disabled (default), 1-Enabled
####### New Parameters added in Release 4.4 #######
# Call Hold Ringback (0-off, 1-on, 2-off with no user control, 3-on with no user control)
call_hold_ringback: 0		; Default 0 (Call Hold Ringback feature is off)
####### New Parameters added in Release 6.0 #######
# Dialtone Stutter for MWI
stutter_msg_waiting: 0		; 0-Disabled (default), 1-Enabled
# RTP Call Statistics (SIP BYE/200 OK message exchange)
call_stats: 0			; 0-Disabled (default), 1-Enabled
xmlDefault.CNF.XML
<?xml version="1.0"?>
-<Default>
-<callManagerGroup>
-<members>
-<member priority="0">
-<callManager>
-<ports>
</ports>
<processNodeName/>
</callManager>
</member>
</members>
<loadInformation6 model="IP Phone 7910"/>
<loadInformation124 model="Addon 7914"/>
<loadInformation9 model="IP Phone 7935"/>
<loadInformation8 model="IP Phone 7940"/>
<loadInformation7 model="IP Phone 7960">P0S3-8-12-00</loadInformation7>
<loadInformation20000 model="IP Phone 7905"/>
<loadInformation30008 model="IP Phone 7902"/>
<loadInformation30002 model="IP Phone 7920"/>
<loadInformation30019 model="IP Phone 7936"/>
<loadInformation30006 model="IP Phone 7970"/>
<loadInformation30018 model="IP Phone 7961"/>
<loadInformation30007 model="IP Phone 7912"/>
</callManagerGroup>
</Default>
The folders "German_Germany"; "germany" and the file German_Germany.aar are in TFTP folder,too. But my phone is doing nothing with this files.
This is the log of TFTP Server:
Rcvd DHCP inform Msg for IP 192.168.0.9, Mac 02:70:7E:7F:09:01 [04/03 13:21:54.559]
Rcvd DHCP inform Msg for IP 192.168.0.9, Mac 02:70:7E:7F:09:01 [04/03 13:21:58.562]
Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac 00:14:A8:92:4D:6D [04/03 13:22:45.892]
Previously allocated address 192.168.0.6 acked [04/03 13:22:45.893]
Connection received from 192.168.0.6 on port 50798 [04/03 13:22:46.037]
Read request for file <CTLSEP0014A8924D6D.tlv>. Mode octet [04/03 13:22:46.038]
File <CTLSEP0014A8924D6D.tlv> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [04/03 13:22:46.038]
Connection received from 192.168.0.6 on port 50798 [04/03 13:22:47.036]
Read request for file <CTLSEP0014A8924D6D.tlv>. Mode octet [04/03 13:22:47.036]
File <CTLSEP0014A8924D6D.tlv> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [04/03 13:22:47.036]
Connection received from 192.168.0.6 on port 50798 [04/03 13:22:51.035]
Read request for file <CTLSEP0014A8924D6D.tlv>. Mode octet [04/03 13:22:51.036]
File <CTLSEP0014A8924D6D.tlv> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [04/03 13:22:51.036]
Connection received from 192.168.0.6 on port 50799 [04/03 13:22:51.056]
Read request for file <SEP0014A8924D6D.cnf.xml>. Mode octet [04/03 13:22:51.057]
File <SEP0014A8924D6D.cnf.xml> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [04/03 13:22:51.057]
Connection received from 192.168.0.6 on port 50800 [04/03 13:22:51.085]
Read request for file <SIP0014A8924D6D.cnf>. Mode octet [04/03 13:22:51.086]
File <SIP0014A8924D6D.cnf> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [04/03 13:22:51.086]
Connection received from 192.168.0.6 on port 50801 [04/03 13:22:51.105]
Read request for file <MGC0014A8924D6D.cnf>. Mode octet [04/03 13:22:51.105]
File <MGC0014A8924D6D.cnf> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [04/03 13:22:51.105]
Connection received from 192.168.0.6 on port 50802 [04/03 13:22:51.124]
Read request for file <XMLDefault.cnf.xml>. Mode octet [04/03 13:22:51.127]
Using local port 65426 [04/03 13:22:51.127]
<XMLDefault.cnf.xml>: sent 3 blks, 1077 bytes in 0 s. 0 blk resent [04/03 13:22:51.135]
Connection received from 192.168.0.6 on port 50803 [04/03 13:22:51.180]
Read request for file <P0S3-8-12-00.loads>. Mode octet [04/03 13:22:51.180]
Using local port 65427 [04/03 13:22:51.180]
<P0S3-8-12-00.loads>: sent 1 blk, 458 bytes in 0 s. 0 blk resent [04/03 13:22:51.183]
Rcvd DHCP inform Msg for IP 192.168.0.9, Mac 02:70:7E:7F:09:01 [04/03 13:24:17.151]
Rcvd DHCP inform Msg for IP 192.168.0.9, Mac 02:70:7E:7F:09:01 [04/03 13:24:20.150]
Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac 00:14:A8:92:4D:6D [04/03 13:24:34.219]
Previously allocated address 192.168.0.6 acked [04/03 13:24:34.220]
Connection received from 192.168.0.6 on port 50823 [04/03 13:24:34.258]
Read request for file <SIPDefault.cnf>. Mode octet [04/03 13:24:34.259]
Using local port 64133 [04/03 13:24:34.259]
Connection received from 192.168.0.6 on port 50823 [04/03 13:24:35.250]
Read request for file <SIPDefault.cnf>. Mode octet [04/03 13:24:35.250]
Using local port 64134 [04/03 13:24:35.250]
Connection received from 192.168.0.6 on port 50823 [04/03 13:24:39.250]
Read request for file <SIPDefault.cnf>. Mode octet [04/03 13:24:39.250]
Using local port 64135 [04/03 13:24:39.250]
<SIPDefault.cnf>: sent 13 blks, 6203 bytes in 0 s. 0 blk resent [04/03 13:24:39.284]
Connection received from 192.168.0.6 on port 50824 [04/03 13:24:39.485]
Read request for file <SIP0014A8924D6D.cnf>. Mode octet [04/03 13:24:39.485]
File <SIP0014A8924D6D.cnf> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [04/03 13:24:39.485]
TIMEOUT waiting for Ack block #1  [04/03 13:24:49.260]
TIMEOUT waiting for Ack block #1  [04/03 13:24:50.251]
Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac 00:14:A8:92:4D:6D [04/03 13:26:50.610]
Previously allocated address 192.168.0.6 acked [04/03 13:26:50.611]
Connection received from 192.168.0.6 on port 50857 [04/03 13:26:50.649]
Read request for file <SIPDefault.cnf>. Mode octet [04/03 13:26:50.649]
Using local port 64137 [04/03 13:26:50.649]
Connection received from 192.168.0.6 on port 50857 [04/03 13:26:51.641]
Read request for file <SIPDefault.cnf>. Mode octet [04/03 13:26:51.642]
Using local port 64138 [04/03 13:26:51.642]
Connection received from 192.168.0.6 on port 50857 [04/03 13:26:55.641]
Read request for file <SIPDefault.cnf>. Mode octet [04/03 13:26:55.641]
Using local port 64139 [04/03 13:26:55.642]
<SIPDefault.cnf>: sent 13 blks, 6203 bytes in 0 s. 0 blk resent [04/03 13:26:55.676]
Connection received from 192.168.0.6 on port 50858 [04/03 13:26:55.874]
Read request for file <SIP0014A8924D6D.cnf>. Mode octet [04/03 13:26:55.875]
File <SIP0014A8924D6D.cnf> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [04/03 13:26:55.875]
TIMEOUT waiting for Ack block #1  [04/03 13:27:05.651]
TIMEOUT waiting for Ack block #1  [04/03 13:27:06.645]
Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac 00:14:A8:92:4D:6D [04/03 13:28:40.670]
Previously allocated address 192.168.0.6 acked [04/03 13:28:40.671]
Connection received from 192.168.0.6 on port 50797 [04/03 13:28:40.813]
Read request for file <CTLSEP0014A8924D6D.tlv>. Mode octet [04/03 13:28:40.813]
File <CTLSEP0014A8924D6D.tlv> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [04/03 13:28:40.814]
Connection received from 192.168.0.6 on port 50797 [04/03 13:28:41.803]
Read request for file <CTLSEP0014A8924D6D.tlv>. Mode octet [04/03 13:28:41.804]
File <CTLSEP0014A8924D6D.tlv> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [04/03 13:28:41.804]
Connection received from 192.168.0.6 on port 50797 [04/03 13:28:45.803]
Read request for file <CTLSEP0014A8924D6D.tlv>. Mode octet [04/03 13:28:45.803]
File <CTLSEP0014A8924D6D.tlv> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [04/03 13:28:45.804]
Connection received from 192.168.0.6 on port 50798 [04/03 13:28:45.824]
Read request for file <SEP0014A8924D6D.cnf.xml>. Mode octet [04/03 13:28:45.824]
File <SEP0014A8924D6D.cnf.xml> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [04/03 13:28:45.824]
Connection received from 192.168.0.6 on port 50799 [04/03 13:28:45.853]
Read request for file <SIP0014A8924D6D.cnf>. Mode octet [04/03 13:28:45.853]
File <SIP0014A8924D6D.cnf> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [04/03 13:28:45.853]
Connection received from 192.168.0.6 on port 50800 [04/03 13:28:45.874]
Read request for file <MGC0014A8924D6D.cnf>. Mode octet [04/03 13:28:45.876]
File <MGC0014A8924D6D.cnf> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [04/03 13:28:45.876]
Connection received from 192.168.0.6 on port 50801 [04/03 13:28:45.895]
Read request for file <XMLDefault.cnf.xml>. Mode octet [04/03 13:28:45.895]
Using local port 64147 [04/03 13:28:45.895]
<XMLDefault.cnf.xml>: sent 3 blks, 1077 bytes in 0 s. 0 blk resent [04/03 13:28:45.898]
Connection received from 192.168.0.6 on port 50802 [04/03 13:28:45.935]
Read request for file <P0S3-8-12-00.loads>. Mode octet [04/03 13:28:45.936]
Using local port 64148 [04/03 13:28:45.936]
<P0S3-8-12-00.loads>: sent 1 blk, 458 bytes in 0 s. 0 blk resent [04/03 13:28:45.937]
Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac 00:14:A8:92:4D:6D [04/03 13:30:28.597]
Previously allocated address 192.168.0.6 acked [04/03 13:30:28.597]
Connection received from 192.168.0.6 on port 50787 [04/03 13:30:28.636]
Read request for file <SIPDefault.cnf>. Mode octet [04/03 13:30:28.636]
Using local port 64149 [04/03 13:30:28.636]
Connection received from 192.168.0.6 on port 50787 [04/03 13:30:29.627]
Read request for file <SIPDefault.cnf>. Mode octet [04/03 13:30:29.628]
Using local port 64150 [04/03 13:30:29.628]
Connection received from 192.168.0.6 on port 50787 [04/03 13:30:33.627]
Read request for file <SIPDefault.cnf>. Mode octet [04/03 13:30:33.628]
Using local port 64151 [04/03 13:30:33.628]
<SIPDefault.cnf>: sent 13 blks, 6203 bytes in 0 s. 0 blk resent [04/03 13:30:33.658]
Connection received from 192.168.0.6 on port 50788 [04/03 13:30:33.856]
Read request for file <SIP0014A8924D6D.cnf>. Mode octet [04/03 13:30:33.856]
File <SIP0014A8924D6D.cnf> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [04/03 13:30:33.857]
Rcvd DHCP inform Msg for IP 192.168.0.9, Mac 02:70:7E:7F:09:01 [04/03 13:30:41.756]
TIMEOUT waiting for Ack block #1  [04/03 13:30:43.637]
TIMEOUT waiting for Ack block #1  [04/03 13:30:44.629]
Rcvd DHCP inform Msg for IP 192.168.0.9, Mac 02:70:7E:7F:09:01 [04/03 13:30:44.759]
Rcvd DHCP inform Msg for IP 192.168.0.9, Mac 02:70:7E:7F:09:01 [04/03 13:32:11.253]
Rcvd DHCP inform Msg for IP 192.168.0.9, Mac 02:70:7E:7F:09:01 [04/03 13:32:14.253]
Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac 00:14:A8:92:4D:6D [04/03 13:33:50.655]
Previously allocated address 192.168.0.6 acked [04/03 13:33:50.656]
Connection received from 192.168.0.6 on port 50795 [04/03 13:33:50.696]
Read request for file <SIPDefault.cnf>. Mode octet [04/03 13:33:50.696]
Using local port 62124 [04/03 13:33:50.696]
Connection received from 192.168.0.6 on port 50795 [04/03 13:33:51.685]
Read request for file <SIPDefault.cnf>. Mode octet [04/03 13:33:51.686]
Using local port 62125 [04/03 13:33:51.686]
Connection received from 192.168.0.6 on port 50795 [04/03 13:33:55.685]
Read request for file <SIPDefault.cnf>. Mode octet [04/03 13:33:55.685]
Using local port 62126 [04/03 13:33:55.685]
<SIPDefault.cnf>: sent 13 blks, 6203 bytes in 0 s. 0 blk resent [04/03 13:33:55.723]
Connection received from 192.168.0.6 on port 50796 [04/03 13:33:55.915]
Read request for file <SIP0014A8924D6D.cnf>. Mode octet [04/03 13:33:55.915]
File <SIP0014A8924D6D.cnf> : error 2 in system call CreateFile Das System kann die angegebene Datei nicht finden. [04/03 13:33:55.915]
TIMEOUT waiting for Ack block #1  [04/03 13:34:05.698]
TIMEOUT waiting for Ack block #1  [04/03 13:34:06.691]
Is there anybody, who can help me with this problem.
