12-20-2014 05:11 AM - edited 03-17-2019 01:23 AM
Dears
im facing a problem in this
i configure my Route pattern as
Local
Pstn Gateway
and the Gateway is configure as you mentioned and the call come just like this
+966122217156
Then i configure Transformation to localize the call as
\+96612.!
Internal
PreDot
and i configure phone transformation as Internal
and the call come to my phone perfectly as
2217156
till now everything is fine
when i check my history call the number shown as
+966122217156
so i configure translated pattern
\+96612.!
Part-Local
CSS-Local
PreDot
Stil the call will not work
i have to Delete the transformation
then the call is working
can you help me in this
the normal full number i dnt know why my phone is 8961 firemware 9-3-4-24 in cucm 9.1
12-21-2014 01:03 PM
after you configure the translation pattern , the result pattern 2217156 should match route pattern.
do you have the proper route pattern ?
Anas
don't forget to rate the helpful posts
01-12-2015 12:37 PM
i solve
thanks
nd sorry for the late replay
01-12-2015 01:00 PM
good to hear that you solve your issue,
If my post help, kindly mark it answer
Anas
