11-26-2014 08:15 AM - edited 03-17-2019 01:06 AM
For a test I'm doing with using 4G as a transport, I have a H.323 voice Gateway with the loopback set up as my voip interface. There is currently no definition for this gateway in CUCM.
interface Loopback0
ip address 10.4.244.1 255.255.255.128
h323-gateway voip interface
h323-gateway voip h323-id C2921-TestRouter-HQ
h323-gateway voip bind srcaddr 10.4.244.1
If I change the ip of the loopback to another IP address that does have a working gateway definition in CUCM
interface Loopback0
ip address 10.4.2.1 255.255.255.128
h323-gateway voip bind srcaddr 10.4.2.1
...I could not get this to communicate with the Call Mgr. I also tried to reset the CUCM RouteList and Gateway.
Assuming I didn't have any IP conflicts, dial-peers are correct, etc......My question is should the router be rebooted when you make an IP change regarding binding of the h323-gateway voip interface or should everything work after the IP address change without a reboot?
The code is 154-3.M1 on a 2921 router.
Thanks.
11-26-2014 08:36 AM
Reboot should not be neccesary
After changing the ip address, did you try pinging the CUCM sourcing the ping from loopback 0 to make sure there isn't a routing issue?
If that is successful
you can try restarting h323 (this will drop active calls)
voice service voip
h323
shutdown
no shutdown
11-26-2014 09:03 AM
Thanks, Israel. I verified connectivity with pings, etc. The IP phones behind the router were also able to communicate with CUCM with no problem. I did some voip debugs showing the dialpeers matched. The problem is that the IP phones could not use the POTS lines used for eternal trunks, and inbound calls didn't work. I verified with CSIM that the trunks were working and I could see calls coming in.
Bouncing the services is probably the right answer. During my testing, I didn't have time for a full router reboot. I'll see if I can recreate the issue and bounce the service. Thanks for the suggestion.
voice service voip
h323
shutdown
no shutdown
