REG Recording with IPT setup
Hi All, Can we record the calls on IP phone in IPT network.? what all servers are required for this. consider as of now i have only CUCM cluster with unity and 7942 IP phone in the network. RegardsPardha.
Hi, I've got a hunt pilot -> hunt list -> line group configured in Call Manager 7.1 the call distribution is fine, but I thought phones that were forwarded were excluded from the group?When a phone is forwarded to voicemail, the phone is still ringin...
I have a large list of translation patterns for outbound speed dials. Works fine for outbound, and of course we can mask the calling ID outbound For inbound, Id like to have names attached to this same list, for example 18005555555 calls and I see ...
Hi all, I have been trying to accomplish this:Dial In to CUCM (through a H.323 VG) from an outside line -> forward the line to CUC -> and before I can reach the call handler that is going to allow me to dial the digits to go outside again, to enter a...
Hi,We have an IP telephony setup with CUCM 9.0.1 and Cisco MediaSense recording server 9.0.1. Calls are recording fine.But we are facing an issue like example Extension 1000 is recording and the all the incoming calls forward to any mobile number on ...
Hello,We have a CUCM 9.1.2.The IP phone can access the Corporate Directory, We can make search usin the first and last name. But cannot call the finded user when pressing the button Dial.And also When pressin the edit dial, it is blank. We've tested ...
Hi All - I am facing an issue with Outbound calls on FXO Line, Inbound is working fine on same Port Analog Line -- FXO -- CUCMvoice-port 0/0/0supervisory disconnect anytonesignal groundStartcptone AEconnection plar 1050 // InboundInitially we had an ...
Hello, Currently when initiating an audio conference we have two toll-free numbers mentioned in the template. One for US the other for Canada. We also have numbers in UK, China, India etc. I cannot find where I can edit this information to include...
Good day!Today I have a funny scenario which I'm not quite sure how to solve, since the beginning of time we are using the Corporate Directory (LDAP) in our CUCM 9, because we support multiple countries our directory numbers starts with the plus sin...
Hi all,I have an issue where I keep receiving the listed RTMT alert from Unity Connection, it appears to be trying to authenticate with CUCM. Can you please advise what is causing this authentication request as Unity connection is synced directly to...
After view some documents and books, i'm Little confuse about mgcp call flow, After the cucm has sent all signaling to devices, the rtp data flows directly between ip phones or this flow is mantained and managed by mgcp gateway?
When I click on Callamanger and select Generate CRS, there is a field in the popup called Domain name which shows the companyname.com.In 10.5, I was told that this is required. Anyone cares to explain in more details? Also, I noticed that there is c...
Hello,I am having difficulties editing BLF/SD on a sidecar for a 7965. Please see attached image. I want to edit the order and add new entries to the side car (Add on module and below). I am not sure if the symbol on the left is for BLF Speed dials o...
After enabling mixed mode in the CLI and rebooted it. How do I verify that the CUCM is now in mixed mode? thanks
I have Callmanager 7.1.5.10000-12 with H323 gateways, gatekeepers for ICM/CVP routing, and PRI's for PSTN. We are in the process of removing physical fax machines and placing them on a FaxCom application. We also have an old FaxCom that the connect...
Subject | Author | Posted |
02-04-2023 02:13 PM | ||
02-01-2023 09:39 PM | ||
01-25-2023 05:07 AM | ||
01-24-2023 11:30 AM | ||
01-19-2023 08:07 AM |
User | Count |
10 | |
5 | |
4 | |
4 | |
2 |
