11-28-2011 08:43 PM - edited 03-16-2019 08:16 AM
I'm configuring H.323 voice gbateway for our branch in UK, appreciate if someone can share the UK dial plan. local, national, international ...etc.
Solved! Go to Solution.
11-28-2011 10:54 PM
Hi Zaid
See below links
http://en.wikipedia.org/wiki/Telephone_numbers_in_the_United_Kingdom
http://www.velocityreviews.com/forums/t235339-uk-dial-plan.html
This is CUCM number plan replace the x with . For h323 config
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008028af3a.shtml
Hope this help
If helpful rate
11-29-2011 01:45 AM
11-28-2011 10:54 PM
Hi Zaid
See below links
Hope this help
If helpful rate
11-28-2011 11:52 PM
Appreciate it Marwan
11-29-2011 01:45 AM
Marwan
Appreciate your help. My rating is + 5
12-02-2011 02:44 AM
The uk.telecom data linked to above is from 2005.
It is inaccurate, incomplete and out of date.
More up-to-date information can be found here:
http://www.aa-asterisk.org.uk/index.php/Number_format
http://www.aa-asterisk.org.uk/index.php/01_numbers
http://www.aa-asterisk.org.uk/index.php/02_numbers
and other pages.
http://www.cisco.com/image/gif/paws/45704/uk_numbering_plan.pdf
There's some errors in the above documents and the data is several years out of date.
There is an error in the following text:
In the UK, local subscriber numbers can be 5, 6, 7, or 8 digits long, which depends on the area code. The UKNP contains four route patterns that overlap, for local access.
The text should read as follows:
In the UK, local subscriber numbers can be 4, 5, 6, 7, or 8 digits long, which depends on the area code. The UKNP contains five route patterns that overlap, for local access.
Add "4,". Change "four" to "five".
There is an item missing from the table:
Number | Route Pattern |
LOCAL-5-DIGIT | [2-9]XXXX |
LOCAL-6-DIGIT | [2-9]XXXXX |
LOCAL-7-DIGIT | [2-9]XXXXXX |
LOCAL-8-DIGIT | [2-9]XXXXXXX |
Add the extra line at the beginning of the table as follows:
LOCAL-4-DIGIT | [2-3]XXX |
Add the new text "LOCAL-4-DIGIT [2-3]XXX" to the beginning of the table.
In the details after this text:
"For example, a gateway in a 2-digit area code with 8-digit subscribers has this filter:"
there is an error in the example code:
(LOCAL-5-DIGIT DOES-NOT-EXIST AND LOCAL-6-DIGIT DOES-NOT-EXIST AND LOCAL-7-DIGIT DOES-NOT-EXIST)
The text should read as detailed below:
(LOCAL-4-DIGIT DOES-NOT-EXIST AND
Add "LOCAL-4-DIGIT DOES-NOT-EXIST AND" to the beginning of the example.
There are two errors in the following text:
For example, calls from Reading (118) to Nettlebed (1491), Maidenhead (1628), Ascot (1276), Bracknell (1344), Aldershot (1252), Basingstoke (1256) and Newbury (1635) are charged at the local rate.
These two area codes changed name in 2003:
For example, calls from Reading (118) to Henley-on-Thames (1491), Maidenhead (1628), Camberley (1276), Bracknell (1344), Aldershot (1252), Basingstoke (1256) and Newbury (1635) are charged at the local rate.
Correct the names for these two area codes.
The following text is incomplete:
The OR statements appear when you add a new Clause to the filter. See Appendix D - Five-digit Subscriber Numbers for lists of area codes with 5-digit subscribers.
The corrected text should read as follows:
The OR statements appear when you add a new Clause to the filter. See Appendix D - Five-digit Subscriber Numbers for lists of area codes with 5-digit subscribers and Appendix E - Four-digit
Subscriber Numbers for lists of area codes with 4-digit subscribers.
Correct the text.
The UK PSTN does not have a uniform structure like the NANP. Area codes can be 2, 3, 4 or 5 digits; subscriber numbers can be 5, 6, 7, or 8 digits; and service codes can be 3, 4, 5, or 6 digits. National numbers can be 10 or 11 digits (including the leading 0).
The UK PSTN does not have a uniform structure like the NANP. Area codes can be 2, 3, 4 or 5 digits; subscriber numbers can be 4, 5, 6, 7 or 8 digits; and service codes can be 3, 4, 5, or 6 digits. National numbers can be 10 or 11 digits (including the leading 0) and there are two 8 digit numbers (0800 1111 and
0845 4647).
Add "4,". Add wording about the two 0800 and 0845 special cases.
In the following text:
"These are the rules for geographic numbers:"
there are some minor changes to make towards the end of this list:
The corrected text reads as follows:
The wording is changed in one rule and there is an additional rule.
Two examples are missing from the table:
Access | Area Code | Subscriber | Place |
0 | 16977 | XXXXX | Brampton 5-digit |
0 | 16977 | XXXX | Brampton 4-digit |
Add the above examples to the table.
The Brampton 016977 area code has both four-digit and five-digit subscriber numbers.
These new number ranges are missing from the table:
Access | SABC | Type | Length |
0 | 300/302/303/306/330/333/343/344/345/370/371/372 | UK wide | 11 |
Add this extra number range.
The following table entry contains an error:
0 | 55X/58X | Corporate | 11 |
The correction is as follows:
0 | 55X | Corporate | 11 |
Correct the data for this number range.
The following number ranges have changed since 2003:
0 | 77X/78X/79X | Mobiles | 11 |
This entry should read as follows:
0 | 71X*/72X*/73X*/74X/75X/7624/77X/78X/79X | Mobiles | 11 |
Add the new number ranges.
*Note: 71X, 72X and 73X are not yet in service.
0 | 844/845 | Local Rate | 11 |
0 | 842/843/844 | Special Rate | 11 |
0 | 845 | Lower Special Rate | 11 |
0 | 870/871 | National Rate | 11 |
0 | 870 | Higher Special Rate | 11 |
0 | 871/872/873 | Lower Premium Rate | 11 |
There is no such tariff as "local rate". This entry:
NHS Direct—08454647 (local rate)
should be reworded to something like:
NHS Direct—0845 4647 (Lower Special Rate)
Correct the wording.
This new number range is missing from the table:
Service Codes | Services |
116XXX | National Helplines |
There is one example missing from the following data:
Category | Numbers* | Example |
AREA-CODE | 2, 3, 4, or 5 digits | 20, 161, 1208 |
AREA-CODE | 2, 3, 4, or 5 digits | 20, 161, 1208, 15395 |
Add ", 15395" to the list.
There is an error in the following data:
SUBSCRIBER | 5, 6, 7, or 8 digits | - |
SUBSCRIBER | 4, 5, 6, 7, or 8 digits | - |
Add "4," to the list.
This new number range, allocated in 2009, is missing from the table:
NATIONAL-HELPLINES | 6 digits | 116123 |
LOCAL-RATE-ACCESS | 844 or 845 | - |
LOCAL-RATE-SUBSCRIBER | 7 digits | 7766554 |
NATIONAL-RATE-ACCESS | 870 or 871 | - |
NATIONAL-RATE-SUBSCRIBER | 7 digits | 1112223 |
The new allocations are as follows:
LOCAL-RATE-ACCESS | 842, 843, 844 or 845 | - |
NATIONAL-RATE-ACCESS | 870, 871, 872 or 873 | - |
Add the additional number ranges.
Note: In the other Cisco UK Numbering Plan document, these are referred to as: LOCALRATE-ACCESS, LOCALRATE-SUBSCRIBER, NATIONALRATE-ACCESS and NATIONALRATE-SUBSCRIBER with only one hyphen.
Note: It is now illegal in the UK to use the terms "local rate" and "national rate" to describe these numbers in advertising as the price of calling them is higher than calling a normal geographic number.
These new number ranges, allocated in 2008, are missing from the table:
UK-WIDE-ACCESS | 30X, 33X, 34X, 37X | - |
UK-WIDE-SUBSCRIBER | 7 digits | 222 3333 |
Add these new number ranges.
The following number type is missing from the table:
LOCAL-4-DIGIT | 4 digits | - |
Add this extra data to the table.
These four-digit subscriber numbers are used in the 016977 area code.
The following tag combination is missing from the list:
LOCAL-4-DIGIT
Add this tag data.
The data for 5+5 format numbers is incomplete and some area codes are linked to the wrong place names:
Location | Area Codes | ||
Dumfries | 13873 | ||
Hornby | 15242 | ||
Kendal | 15394 | 15395 | 15396 |
Wigton | 16973 | 16974 | |
Penrith | 17683 | 17684 | 17687 |
Gosforth | 19467 |
The corrected data is as follows:
Langholm | 13873 |
Hornby-with-Farleton | 15242 |
Hawkshead | 15394 |
Grange-over-Sands | 15395 |
Sedbergh | 15396 |
Wigton | 16973 |
Raughton Head | 16974 |
Brampton | 16977 |
Appleby-in-Westmorland | 17683 |
Pooley Bridge | 17684 |
Keswick | 17687 |
Gosforth | 19467 |
Correct the data for these number ranges.
The following number ranges have changed since 2003 and should be DELETED from the table:
Location | Area Codes | 5-digit Subscriber Number Ranges | |
Forfar | 1307 | 8[2-4]XXX | DELETE THESE TWO ENTRIES |
Kircudbright | 1557 | 50XXX |
These area codes were upgraded to use only 6-digit subscriber numbers at least several years ago.
The following number ranges were mis-classified by Ofcom for many years and should be DELETED from the table:
Wigton | 1697 | 7[23]XXX | DELETE THIS ENTRY |
This entry should show the 4-digit subscriber numbers found in the 016977 Brampton area code.
This data therefore belongs in a different table and in a different format: e.g. "16977 [23]XXX". See the final item.
Location | Area Codes | 5-digit Subscriber Number Ranges | ||
Buxton | 1298 | 2[2-7]XXX | 7[0-47-9]XXX | 8[3-5]XXX |
The correct data is as follows:
Buxton | 1298 | 2[2-8]XXX | 7[0-47-9]XXX | 8[3-5]XXX |
The part "[2-7]" changes to "[2-8]".
Alton | 1420 | 2[23]XXX | 8[02-9]XXX |
Alton | 1420 | 2[23]XXX | 8XXXX |
The part "[02-9]" changes to "X".
St. Austell | 1726 | 6[13-7]XXX | 7[0-7]XXX |
St. Austell | 1726 | 6[13-9]XXX | 7[0-7]XXX |
The part "[13-7]" changes to "[13-9]".
The following number range is missing from the table:
Location | Area Code | 5-digit Subscriber Number Ranges |
Penrith | 1768 | 88[2-46-8]XX |
The above number range needs to be added to the table.
The following area codes changed name in 2003:
There's a spelling mistake in the table:
Correct the spelling for this area.
A new section is needed, listing the details of 4-digit subscriber numbers:
Numbers beginning either 0169772 and 0169773 are in a 5-digit code area and have a 4-digit subscriber number:
A new table is needed as follows:
Location | Area Code | 4-digit Subscriber Number Ranges |
Brampton | 16977 | [23]XXX |
Add a new table to show the data for this number range.
Originally posted 2011-12-01. Minor corrections and additions 2012-01-05.
* Originally posted 2011-12-01. Minor corrections and additions 2012-01-05.
01-14-2012 10:51 AM
That was quick! After informing Cisco of the above errors in November 2011, all the problems were fixed about 8 weeks later.
Both the referenced HTML page and the PDF document have been updated to incorporate all of the above changes and additions.
In other news, Ofcom recently (December 2011) issued an Errata to the UK National Telephone Numbering Plan correcting spelling mistakes for nine place names in the UK area code list.
Most of these errors were introduced in the April 2003 version of the number plan (though some of the errors existed before that time).
The corrected names are detailed at: http://stakeholders.ofcom.org.uk/telecoms/numbering/ and below.
Area Code | Current Geographic Area Name | Corrected Geographic Area Name |
01271 | Barnstable | Barnstaple |
01284 | Bury-St-Edmunds | Bury St Edmunds |
01286 | Caernarvon | Caernarfon |
01289 | Berwick-on-Tweed | Berwick-upon-Tweed |
015395 | Grange-Over-Sands | Grange-over-Sands |
01559 | Llandyssul | Llandysul |
01877 | Callandar | Callander |
01889 | Rugely | Rugeley |
01934 | Weston-Super-Mare | Weston-super-Mare |
