H323 gateway configuration with E1 PSTN
martyveerdonk
can somebody help me with a configuration template/example for a H323 gateway that is connected to the PSTN via an E1 controller.
Thanks in advance!
royalblues
Level 10
Level 10
Friend
what are the digits that will be sent to you by the provider
here is a sample config
card type e1 1 1 (required for 2Gen cards)
controller E1 1/0
framing NO-CRC4 (will depend on ur service provider)
pri-group timeslots 1-31
isdn switch-type primary-net5
dial-peer voice 1 pots
destination-pattern 9.T
incoming called-number .
direct-inward-dial
port 1/0:15
dial-peer voice 2 voip
destination-pattern 800 (will depend on the digits sent)
session target ipv4:
Also you will have to use a translation pattern to translate the digits that are sent by ISP to your extension range
Narayan
