H323 Gateway/FXO ports
aaron.banks11
I have a couple of questions about configuring FXO ports in an H323 gateway.
1.  For every voice port I use, do I need dial peers for each individual port?  So...voice port 0/0/0 - has a 911 dial peer, local, LD, international.  And same for the second voice port, so if I have 4 voice ports and the above mentioned dial peers, that would be a total of 16 dial peers (for argument's sake).  Or is there a better/more efficient way of doing it?
2. Other than adding the gateway in call manager, is there anything else?  i.e. do I need to add a separate gateway for the FXO ports?  I don't believe so, but I have to ask since I don't normally configure H323 gateways.
Thanks taking the time to answer :)
Jaime Valencia
1 https://supportforums.cisco.com/discussion/10436306/configuring-fxo-port-trunk-group
2 No, you just need the GW as H.323 on CUCM to route to it, then the GW needs the config for call routing as well.
java
if this helps, please rate
Thanks Jaime!  That link makes perfect sense.
