04-20-2011 05:48 AM - edited 03-16-2019 04:37 AM
I've read Cisco IOS command reference, but I'm still not sure about the purpose of "h323-gateway voip interface" command.
Moreover, I was trying to understand the difference between "h323-gateway voip interface" and "h323-gateway voip bind srcaddr".
Here's my config on the gateway router:
interface Fa0/0
ip address 192.168.1.254 255.255.255.0
h323-gateway voip bind srcaddr 192.168.1.254interface loopback0
ip address 10.1.1.254 255.255.255.0
h323-gateway voip id GK ipaddr 10.2.2.254
h323-gateway voip h323-id CUCME
h323-gateway voip tech-prefix 408
From my understanding, the "h323-gateway voip interface" command should dictate the source address that being used to communicate with gatekeeper. i.e. it should be 10.1.1.254 (loopback0)
However, when I do a "show gatekeeper endpoint" command on the gatekeeper router, it's showing the RAS address as 192.168.1.1.254 (Fa0/0). How can I make the gateway router to use loopback0 communicate with GK, while using the Fa0/0 interface communicate with other H323 peers (such as CUCM)?
GK#show gatekeeper endpoint
GATEKEEPER ENDPOINT REGISTRATION
CallSignalAddr Port RASSignalAddr Port Zone Name Type Flags
192.168.1.254 1720 192.168.1.254 60745 GK VOIP-GW
H323-ID: CUCME
Voice Capacity Max.= Avail.= Current.= 0
Total number of active registrations = 1
P.S.
Thanks!
Michael
07-11-2011 06:51 AM
I cant remove it, since this router acting as cme is connected with othwe cme too.
07-11-2011 07:22 AM
You don't need this cmd if call is coming from another CME. You don't registered this as h323 GW to CME.
07-12-2011 06:05 AM
Just to add, I always thought the "h323-gateway voip bind srcaddr X.X.X.X" commend was to tell the destination where the IP packets came from particular if you have loopback address otherwise you can have one way transmission , loss of packets etc
03-08-2022 04:53 AM
Hi Amer,
I am connecting Cisco 3945 with Dell Switch on which Cumulus Linux in running. I will binding both the ports of 3945 in Port channel and connected it to Cumulus Switch.
Can I configured h323-gateway voip bind srcaddr command on Layer 3 Port channel connecting to Cumulus Switch.
Did I need to also add h323-gateway voip interface on the Interface level .
