Has anyone deployed a 2911 as an h323 gateway/SRST router with CCM 4.1.3
kdonnelly
Customer has CCM 4.1.3 with 2811 routers as h323/ SRST gateways. They are planing to upgrade the wan to MPLS and the Telco has given them 2911 routers. So I'm wondering if anyone has used a 2900 router as an h323/SRST with CCM 4.X
Thomas Dominic
It shouldn't make a difference if you are configuring them as as H.323 G/W. It is a peer to peer protocol and doesn't rely on the Call Manager, SRST also should not be a problem; it's MGCP that you have to worry about all this .
Thomas
P.S. Please rate helpful post
