Help please Unity Connection
Deal all
     I have a problem now I'm creating call handle finish already when I call to greeting have delay 10s before into greeting after that I hear lady said "SORRY"
then  I push number extension I hear lady said "Wait While I Transfer Your Call" (This problem at transfer rule page I change Transfer Calls To greeting>>>>extension and choose transfer type to release to switch It blank no ring back tone)
Where I make mistake please help
6 Replies 6
Jaime Valencia
What kind of integration do you have??
Have you made sure there is no overlapping in CUCM?
java
if this helps, please rate
Dear Jaime
    My product is    VG>>>>>>CUCM>>>>>>unity.sorry I don't understand overlapping in cucm ?
Thank
Overlapping dial plan
java
Hi Jaime
      I make sure not overlapping on dial plan because I checked already do you have any idea?
Thank
Then you can use the port status monitor to confirm the call is sent right away to CUC, and if the delay is really in CUC.
java
this problem is solve already
