11-30-2010 11:44 AM - edited 03-16-2019 02:11 AM
Hi Guys,
I am try configure the IPMA in CallManager version 7.1 by the first time and I am having many difficults. I read the documentation about SRND and apply the configuration, but, when start the Applicative Manager I received the message error of login or password. Are there any procedure to configure step-by-step IPMA for version CallManager version 7.x in the Cisco site?
Wilson Santana
Solved! Go to Solution.
11-30-2010 04:25 PM
There's an IPMA wizard that does most of the configuration for you, you can actually just click next through most of it to get it working if you want the easiest way of setting it up.
11-30-2010 06:53 PM
The instructions for both deployments are here
11-30-2010 04:25 PM
11-30-2010 06:53 PM
