Help with CUBE MoH
The problem is that internally (extensions) the MoH works, but for incoming SIP solution does not work.
configuration commands and applied are:
  • ip multicast-routing
  • ccm-manager music-on-hold
on telephony-service
  • moh "music-on-hold.au"
  • multicast moh 239.10.16.16 port 2000
thanks in advance
best regards
Juan Jose
sumdingwong
Does your SIP provider support multicast MOH?
I do not know, this solution is configured remotely in Denver USA and the company name is INTEGRA. Is there any way to see that?
Did you try searching, similar question has been asked few times before with very good responses.
Chris
