Help with SIP to PRI to SIP using two AS5400 GW's
Hello everyone,
I'll try my best to explain what I need help with and what the peers 'might' be to give you a better Idea.
I have two AS5400 GW, I need voice calls (a block of DID's) to hit a dial-peer and then to a trunk-group peer that will send the call out to the PRI/T1 card and out to another AS5400 GW (with crossover cable),
I seem to have the first peer working and i have selected a small block to hit this peer, so far so good see below:
dial-peer voice 11022 voip
description KBDL TEST DID's Inbound
session protocol sipv2
incoming called-number 310526839.
voice-class codec 1
dtmf-relay rtp-nte
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
no vad
So far so good but still not sure that config is 'fully' correct but it works for now, I do see incoming calls when running: sh voice call stat  to that new test peer.
Now, I need that peer to send that call over to the other peer that will send it over to the internal PRI card but it's landing of the production peer 11111 therefore shows 11022/11111
I need this to show 11022/11023 when running: sh voice call stat so i know it's working.
11023 is the other peer and also not sure it's correct.  See below:
dial-peer voice 11023 pots
description X-out to GW-2
trunkgroup kbdb
destination-pattern 310526839.
I believe the digit patterns should match on both peers but I could be wrong.
I have two other peers but that is for our production traffic and I need help to create those test peers.
On top of the config's I have created the trunk group of:
trunk group kbdb
hunt-scheme longest-idle
Does anyone know what the correct configs might be?  I've been at this for 5 days and I'm not a Cisco expert and all new to me.
Please advise.
Thanks in advance,
Alexander..
0 Replies 0
