We have a number of users sharing devices (Android based) who would need to sign-out and reset jabber every time they complete a shift. Is there any way to do reset jabber on every sign-out?thanks.
Hi, Can someone tell me how to change the display name of a 7821 phone from cucm? I did various methods such as changing the Display (Internal Caller ID) & ASCII Display (Internal Caller ID) andalso changing Description, Alerting Name, and ASCII Al...
Hi, I have a problem with calls being dropped at constantly at random intervals. Can someone point me in the right direction to troubleshoot? CUCM at a centralized location connected over a LWAN to the branch router on site. Thanks
Hi Guys, The default message on the phone displays when there is a voice mail, can this be changed to show how many voicemail messages are queued ?
does anyone know where to find a list of all the options you can use ? for example i m aware of these one http://10.10.10.10/emapp/EMAppServlet?device=SEP123456789&doLogout=true http://10.10.10.10/emapp/EMAppServlet?device=SEP123456789&&userid=Lo...
Hi guys/gals, This has been asked before but the thread went dead. in 2015. We have Cisco Unity CM 9.1.2 and recently installed InformerCast so we can page, set bells and distribute emergency warnings. According to the tech that configured Info...
Hi Cisco Community, I'm a new French customer of Cisco and I need your help to setup my SIP Line on my new Cisco phone 8811. I try to setup it with all information i have from my SIP provider: sip3.ovh.fr (91.121.129.159) user password but I ...
I am migrating 7 CUCM servers onto new hardware and keeping the Ip Addresses the same. I cannot use PCD for the migration as it is version 9.1 to 9.1 and it is not supported. The only method I can use is to switch off the legacy server and then do a ...
Hi Experts, Lets see who will be ripping $20,200.00 out of my hands. We have replaced x2 CME 4.3 with x2 BE6000s CUCM 11.x However loaded on the CME's are 50 Enhanced Licenses on each so 100 total. PLEASE tell me it is possible to extract th...
I need some help getting my 4 port FXO module working on my 2901 router. I realize that I need to use the voice-port command to activate and configure the module but I don't know what port(s) the 4 port FXO modules is using. I performed a sh interfac...
Hello,Can I use Single Number Reach to achieve the following scenario:The incoming call will hit a Hunt Number --> Group of Extensions --> in case no answer the call will be forwarded to Mobile Number (I will use here SNR to keep the signalling withi...
Hi all, Can you please advise on best way to get all required info to complete the SME sizing tool? The SME sizing tool requires the following input parameters: BHCA per user for each trunk interface to leaf clusters for intercluster callsBHCA per us...
Hello, at the moment we´re restructuring our network. Currently we´re using more than 300 Cisco Vo-IP-Telephones in two /24 subnets. To make our network easier, we would like to transfer the two /24 subnets into a /23 subnet.We´re using the Cisco Uni...
I have a raised a request to the respective team to VMotion the existing VM running CUCM 10.5(2) version from existing host to a new host. So I would like to know about the things regarding CUCM which I should note down or take care before and after ...
I have setup CUCM and unity to have voicemail, I can ring an extension and leave a message, the message light then comes on on that phone but when I dial the voicemail I enter the pin and then each time it asks me to setup a greeting? I cannot get...
Subject | Author | Posted |
04-30-2025 05:24 AM | ||
04-30-2025 01:54 AM | ||
04-29-2025 03:01 PM | ||
04-28-2025 05:35 AM | ||
04-26-2025 05:48 AM |
User | Count |
3 | |
2 | |
1 | |
1 | |
1 |
