High-Density Extension Module
Labanelamia
Good morning everyone,
I have BE(6000)
EVM-HD-8FXS/DID High density voice/fax extension module - 8 FXS/DID 1
EM-4BRI-NT/TE 4-port voice/fax expansion module - BRI (NT and TE) 1
VIC2-4FXO Four-port Voice Interface Card - FXO (Universal) 4
I need to configure fax , i do some research about it but i don't find an example about how to use the 8 FXS (High-Density Extension Module)  , when i do show run on the router i just found  my  4 BRI inteface and 16 FXO !!!  Can someone give me clarification about it, maybe there is something that escapes me.
interface BRI1/0
 no ip address
interface BRI1/1
 no ip address
interface BRI1/2
 no ip address
interface BRI1/3
 no ip address
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
voice-port 0/3/0
voice-port 0/3/1
voice-port 0/3/2
voice-port 0/3/3
2 Accepted Solutions
The module is detected and you are having SM-NM-ADPTR which is a prerequisite. However, PVDM3-16 seems to be low compared to the number of analog ports and BRI channels running on the router.
Can you please enable console logging, connect through console and reload the router. Then share the console logs and lets see what is happening when the router reboots.
Additionally, please share the output of show diag
Rob Huffman
Hi there,
Mohammed is most correct in his assessment of the lack of DSP resources here (+5) If you use the DSP calculator at this link you will see you need a much higher DSP count;
http://www.cisco.com/web/applicat/dsprecal/dsp_calc.html
I did a quick calculation based on your needs and it showed these results (need 1- PVDM3-64);
Router: 2911
IOS: 15.1(4)M
DSP Modules Required:
PVDM3-64: 1
8 Replies 8
please share the following:
1. show inventory
2. IOS Version
3. Router Model
:::::::::::::::::::::::::::::::::::::::::::#    sh version::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.2(4)M6a, RELEASE SOFTWARE (fc1)
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
Cisco CISCO2911/K9 (revision 1.0) with 479232K/45056K bytes of memory.*
::::::::::::::::::::::::::::::::::::::::::#   sh inventory::::::::::::::::::::::::::::::::::::::::::::::::::::::
NAME: "CISCO2911/K9", DESCR: "CISCO2911/K9 chassis, Hw Serial#: FGL183211W4, Hw Revision: 1.0"
PID: CISCO2911/K9      , VID: V07 , SN: FGL183211W4
NAME: "2nd generation four port FXO voice interface daughtercard on Slot 0 SubSlot 0", DESCR: "2nd generation four port FXO voice interface daughtercard"
PID: VIC2-4FXO         , VID: V04 , SN: FOC182937W9
NAME: "2nd generation four port FXO voice interface daughtercard on Slot 0 SubSlot 1", DESCR: "2nd generation four port FXO voice interface daughtercard"
PID: VIC2-4FXO         , VID: V04 , SN: FOC18293812
NAME: "2nd generation four port FXO voice interface daughtercard on Slot 0 SubSlot 2", DESCR: "2nd generation four port FXO voice interface daughtercard"
PID: VIC2-4FXO         , VID: V04 , SN: FOC182937JU
NAME: "2nd generation four port FXO voice interface daughtercard on Slot 0 SubSlot 3", DESCR: "2nd generation four port FXO voice interface daughtercard"
PID: VIC2-4FXO         , VID: V04 , SN: FOC1829377G
NAME: "PVDM3 DSP DIMM with 16 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 16 Channels"
PID: PVDM3-16          , VID: V01 , SN: FOC183143VF
NAME: "Network Module Adapter for SM Slot on Slot 1", DESCR: "Network Module Adapter for SM Slot"
PID: SM-NM-ADPTR       , VID: V01, SN: FOC182879JF
NAME: "High Density Voice Module - 8FXS/DID on Slot 1", DESCR: "High Density Voice Module - 8FXS/DID"
PID: EVM-HD-8FXS/DID   , VID: V05 , SN: FOC18303B3K
NAME: "Four port BRI NT/TE voice interface daughtercard on Slot 1 SubSlot 0", DESCR: "Four port BRI NT/TE voice interface daughtercard"
PID: EM-4BRI-NT/TE     , VID: V03 , SN: FOC18108QSR
NAME: "C2911 AC Power Supply", DESCR: "C2911 AC Power Supply"
PID: PWR-2911-AC       , VID: V05 , SN: QCS18231Z8K
hi Mohammed al baqari, thank you for your answer, how can i resolve this problem of  dsp resources.
console logs:
Jan 27 10:27:48.974: %SYS-5-RELOAD: Reload requested by Cisco on console. Reload Reason: Reload Command.
Copyright (c) 2012 by cisco Systems, Inc.
Total memory size = 512 MB - On-board = 512 MB, DIMM0 = 0 MB
CISCO2911/K9 platform with 524288 Kbytes of main memory
Main memory is configured to 72/-1(On-board/DIMM0) bit mode with ECC enabled
Readonly ROMMON initialized
program load complete, entry point: 0x80803000, size: 0x1b340
IOS Image Load Test
___________________
Digitally Signed Release Software
program load complete, entry point: 0x81000000, size: 0x5e8b3f8
Self decompressing the image : ############################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################### [OK]
Smart Init is enabled
smart init is sizing iomem
                 TYPE      MEMORY_REQ
               PVDM 0      0x00200000
            SM Slot 1      0x00600000
    Onboard devices &
         buffer pools      0x0228F000
               TOTAL:      0x02A8F000
Rounded IOMEM up to: 44Mb.
Using 8 percent iomem. [44Mb/512Mb]
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Tue 15-Apr-14 09:45 by prod_rel_team
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Processor board ID FGL183211W4
3 Gigabit Ethernet interfaces
4 ISDN Basic Rate interfaces
1 terminal line
16 Voice FXO interfaces
8 Voice FXS interfaces
4 Voice NT or TE BRI interfaces
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
Press RETURN to get started!
*Jan  2 00:00:04.683: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c2900 Next reboot level = ipbasek9 and License = ipbasek9
*Jan  2 00:00:04.855: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c2900 Next reboot level = uck9 and License = uck9
*Jan 27 10:29:53.627: %IFMGR-7-NO_IFINDEX_FILE: Unable to open nvram:/ifIndex-table No such file or directory
*Jan 27 10:29:53.635: c3600_scp_set_dstaddr2_idb(184)add = 80 name is Embedded-Service-Engine0/0
*Jan 27 10:30:03.099:
Repla%PVDM-6-UNSUPPORTED: Codec G.723 is not supported on PVDM3.
*Jan 27 10:30:40.699:  Create voice ha process now......
*Jan 27 10:30:40.703: %DSPRM-3-INSUFFICIENT_DSP:
voice-port :   1/0/1 Not initialized due to insufficient DSP resources
voice-port : 1/0/2 Not initialized due to insufficient DSP resources
*Jan 27 10:30:40.703ce <myuser> and <mypassword> with the username and password you want
to use.
IF YOU DO NOT CHANGE THE PUBLICLY-KNOWN CREDENTIALS, YOU WILL NOT BE ABLE
TO LOG INTO THE DEVICE AGAIN AFTER YOU HAVE LOGGED OFF.
For more information about Cisco CP please follow the instructions in the
QUICK START GUIDE for your router or go to http://www.cisco.com/go/ciscocp
User Access Verification
Username: : %DSPRM-3-INSUFFICIENT_DSP:
voice-port : 1/0/3 Not initialized due to insufficient DSP resources
voice-port : 1/0/4 Not initialized due to insufficient DSP resources
*Jan 27 10:30:40.707: %DSPRM-3-INSUFFICIENT_DSP:
voice-port : 1/0/5 Not initialized due to insufficient DSP resources
voice-port : 1/0/6 Not initialized due to insufficient DSP resources
voice-port : 1/0/7 Not initialized due to insufficient DSP resources
voice-port : 1/0/8 Not initialized due to insufficient DSP resources
voice-port : 1/0/9 Not initialized due to insufficient DSP resources
voice-port : 1/0/10 Not initialized due to insufficient DSP resources
voice-port : 1/0/11 Not initialized due to insufficient DSP resources
*Jan 27 10:30:40.743: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0, changed state to up
*Jan 27 10:30:40.743: %LINK-3-UPDOWN: Interface GigabitEthernet0/0, changed state to down
*Jan 27 10:30:40.743: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to down
*Jan 27 10:30:40.743: %LINK-3-UPDOWN: Interface GigabitEthernet0/2, changed state to down
*Jan 27 10:30:40.743: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI1/0, changed state to down
*Jan 27 10:30:40.743: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI1/0:1, changed state to down
*Jan 27 10:30:40.743: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI1/0:2, changed state to down
*Jan 27 10:30:40.743: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI1/1, changed state to down
*Jan 27 10:30:40.743: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI1/1:1, changed state to down
*Jan 27 10:30:40.743: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI1/1:2, changed state to down
*Jan 27 10:30:40.743: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI1/2, changed state to down
*Jan 27 10:30:40.743: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI1/2:1, changed state to down
*Jan 27 10:30:40.743: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI1/2:2, changed state to down
*Jan 27 10:30:41.887: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0, changed state to down
*Jan 27 10:30:41.887: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to down
*Jan 27 10:30:41.887: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/2, changed state to down
*Jan 27 10:30:43.067: %SYS-6-CLOCKUPDATE: System clock has been updated from 10:30:43 UTC Wed Jan 27 2016 to 11:40:43 WZone Wed Jan 27 2016, configured from console by console.
*Jan 27 10:30:43.243: %SYS-5-CONFIG_I: Configured from memory by console
*Jan 27 10:30:44.263: %LINEPROTO-5-UPDOWN: Line protocol on Interface Loopback1, changed state to up
*Jan 27 10:30:44.927: %LINK-3-UPDOWN: Interface BRI1/0, changed state to up
*Jan 27 10:30:45.515: %LINK-3-UPDOWN: Interface BRI1/1, changed state to up
*Jan 27 10:30:45.515: %LINK-5-CHANGED: Interface Embedded-Service-Engine0/0, changed state to administratively down
*Jan 27 10:30:45.515: %LINK-5-CHANGED: Interface GigabitEthernet0/1, changed state to administratively down
*Jan 27 10:30:45.515: %LINK-5-CHANGED: Interface GigabitEthernet0/2, changed state to administratively down
*Jan 27 10:30:46.067: %LINK-3-UPDOWN: Interface BRI1/2, changed state to up
*Jan 27 10:30:46.127: %LINK-3-UPDOWN: Interface BRI1/3, changed state to up
*Jan 27 10:30:46.519: %LINEPROTO-5-UPDOWN: Line protocol on Interface Embedded-Service-Engine0/0, changed state to down
*Jan 27 10:30:49.063: %SYS-5-RESTART: System restarted --
*Jan 27 10:30:49.107: %SNMP-5-COLDSTART: SNMP agent on host yourname is undergoing a cold start
*Jan 27 10:30:49.723: %SYS-6-BOOTTIME: Time taken to reboot after reload =  183 seconds
Jan 27 10:31:16.115: %DSPRM-5-UPDOWN: DSP 1 in slot 0, changed state to up
Jan 27 10:31:17.467: %LINK-3-UPDOWN: Interface Foreign Exchange Office 0/0/0, changed state to up
Jan 27 10:31:17.731: %LINK-3-UPDOWN: Interface Foreign Exchange Office 0/0/1, changed state to up
Jan 27 10:31:17.883: %LINK-3-UPDOWN: Interface Foreign Exchange Office 0/0/2, changed state to up
Jan 27 10:31:18.035: %LINK-3-UPDOWN: Interface Foreign Exchange Office 0/0/3, changed state to up
Jan 27 10:31:18.187: %LINK-3-UPDOWN: Interface Foreign Exchange Office 0/1/0, changed state to up
Jan 27 10:31:18.339: %LINK-3-UPDOWN: Interface Foreign Exchange Office 0/1/1, changed state to up
Jan 27 10:31:18.491: %LINK-3-UPDOWN: Interface Foreign Exchange Office 0/1/2, changed state to up
Jan 27 10:31:18.643: %LINK-3-UPDOWN: Interface Foreign Exchange Office 0/1/3, changed state to up
Jan 27 10:31:18.795: %LINK-3-UPDOWN: Interface Foreign Exchange Office 0/2/0, changed state to up
Jan 27 10:31:18.947: %LINK-3-UPDOWN: Interface Foreign Exchange Office 0/2/1, changed state to up
Jan 27 10:31:19.099: %LINK-3-UPDOWN: Interface Foreign Exchange Office 0/2/2, changed state to up
Jan 27 10:31:19.251: %LINK-3-UPDOWN: Interface Foreign Exchange Office 0/2/3, changed state to up
Jan 27 10:31:19.403: %LINK-3-UPDOWN: Interface Foreign Exchange Office 0/3/0, changed state to up
Jan 27 10:31:19.555: %LINK-3-UPDOWN: Interface Foreign Exchange Office 0/3/1, changed state to up
Jan 27 10:31:19.707: %LINK-3-UPDOWN: Interface Foreign Exchange Office 0/3/2, changed state to up
Jan 27 10:31:19.859: %LINK-3-UPDOWN: Interface Foreign Exchange Office 0/3/3, changed state to up
As expected, the module isn't initialized due to lack of DSPs. This is listed in your logs.
Rob, Thx for taking the step to do the calculations of DSP requirement
Actually I noticed the dsp resource problems, how can I resolve this problem ? any suggestions please .
You need to buy additional DSPs. As Rob highlighted based on his calculations you need at least PVDM3-64. However, you use the online calc provide by Rob if you want more granular calculations based on your requirement.
This is a hardware limitation which can't be overcomed. You can't use all cards with the current DSP module
Rob Huffman
Hi there,
Router: 2911
IOS: 15.1(4)M
PVDM3-64: 1
