Hosted Voip for Small Business
ncowger
We are looking for a hosted voip solution for small businesses (Less than 25 phones) that can use Cisco IP phones, not SPA phones.  Does anyone have any experience with any reliable options?
7 Replies 7
yahsiel2004
Level 7
Level 7
You can get a 2901 or 2911 and run Cisco Call Manager Express.
http://www.cisco.com/c/en/us/products/collateral/routers/2900-series-integrated-services-routers-isr/data_sheet_c78_553896.html
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm.html
HTH Regards,
Yosh
HTH Regards, Yosh
I'm looking for something that is hosted.  Internet based.
Take a look at West IP - http://westipc.com/
Hailey
Thank you David!  I will look into this one.
No problem - I believe their UC service offering is called MaxxPoint...has a lot of features and they've been around a while. They are a Cisco partner and a Gartner leader in UCaaS.
Hailey
hi
+5 for Yosh , as he mentioned you can go to Cisco CME solution which is router based . You can use Cisco router 2nd generation as 2901 , or 2911 .You have to ask yourself one question regarding if you will need a service module for voice mail , or not . you have also to do a survey for no.of users which will be supported by your CME in future . Kindly check the below link which will inform you more information about each series .
thanks
please rate all useful information
I'm quite familiar with CME.  I've deployed it many times.  It's not always the correct solution even for a small business.  I have more than one scenario where a CME isn't an option.  For example. I have a business that has 10 users that all work from home.  They would like a central phone number and extensions for each employees desk phone.  Also, shared VM.  This all needs to be cloud based.
