04-11-2017 01:19 PM - edited 03-17-2019 10:04 AM
We need to hot swap voice vlans on cisco 7942 IP phones as our companies voice vlan is out of address space. I know, best practice is to have a single broadcast domain per department / switch / etc, but I did not build this mess I inherited it.
Current Topology:
Catalyst WS-C4500X-32 SSO -> WS-C2960X-48FPD-L (Stack Config) -> IP Phone
Voice VLan1
IP Add 192.168.1.254
IP DHCP-HELPER 192.168.10.1
Voice VLan2
IP Add 192.168.2.254
Int GI 5/0/1 (IP Phone)
switchport access vlan 6
switchport mode access
switchport voice vlan 1
srr-queue bandwidth share 1 30 35 5
srr-queue bandwidth shape 10 0 0 0
priority-queue out
mls qos trust device cisco-phone
mls qos trust cos
auto qos trust
no mdix auto
spanning-tree portfast
service-policy input AUTOQOS-SRND4-CISCOPHONE-POLICY
end
DHCP Config Settings:
150 TFTP Server IP Address: 192.168.1.15, 192.168.1.16
If I unbox a new phone then connect to voice vlan 2, the phone will retrieve TFTP config files from CUCM, then proceed to boot. However; If I use an existing phone and simply switch the voice vlan then, shut / no shut the port. The phone will never register with the call manager to download config files. The process ends at Config CM List; 192.168.1.15; 192.168.1.16; 192.168.1.254 I am interested in why the last option is shown 192.168.1.254 as it is my gateway and not included in DHCP option 150.
I have roughly one hundred phones to migrate to this new voice vlan.
If anyone can help ? ! Thanks.
Solved! Go to Solution.
04-11-2017 03:39 PM
I did a similar change the other day and just changing the phones to the new VLANs was enough, I didnt even neet to shut/unshut the port.
The fact that you have functioning phones in VLAN2 proves that routing to and from that VLAN to cucm works. what happens if you first shut the port and then change the vlan to 2 and then unshut the port?
also, are there maybe static IP addresses configured on these phones? (seeing you inherited a mess ;-) )
Please rate if useful
04-11-2017 03:39 PM
04-12-2017 08:37 AM
04-18-2017 08:47 AM
Could you by chance send me your list of DHCP options? The packet capture has shown a DHCP release and request; however, the client is requesting an ip address in the wrong vlan.
04-19-2017 12:20 PM
This is the actual answer to my problems.
https://social.technet.microsoft.com/Forums/windows/en-US/c36b6a70-59a9-40dd-8c1d-aa87a4032aac/possible-to-ignore-renewal-dhcprequest-and-force-dhcp-clients-to-start-over-dhcpdiscover?forum=winserverNIS
This did not work either.
No use of static IP address in VLAN2. I created a new dedicated VLAN to split my scope and it only has a single address in it.
I will be running a packet capture on the phone, I will post results.
