10-07-2008 12:12 PM - edited 03-15-2019 01:47 PM
I have a CM 6.1 system and I have reports of people calling 911. Is there a way in CM 6 to find out what DN's dialed 911?
I know in CM 4 you had to do a custom SQL query, but obviously thats an issue in CM 6.
10-07-2008 12:28 PM
You can wait until after midnight(after CDR reports are processed), then go to your call manager's CAR site http://iphere/car/login.asp
login with your car administrator login, then choose export CDR records. It exports your entire call history into a csv file that you can then import into excel/access.
Robert
11-14-2008 11:40 AM
you can do it in "almost" real time. export your CDR records then import them into a sql database. use the following sql query to find the extension
DECLARE @StartDateTime DATETIME
,@EndDateTime DATETIME
SELECT @StartDateTime = '11/11/2008 08:00'
SELECT @EndDateTime = '11/12/2008 23:00'
select callingPartyNumber,originalCalledPartyNumber,finalCalledPartyNumber,globalCallID_callId,
duration,origCalledPartyRedirectReason,lastRedirectRedirectReason,
datetimeorigination = DATEADD(hour,-5,(dateadd(second ,dateTimeOrigination, '1/1/1970')))
,datetimedisconnect = DATEADD(hour,-5,(dateadd(second ,dateTimedisconnect, '1/1/1970')))
from cdr --this is the table you imported data into--
where finalcalledpartynumber = ('911')
AND DATEADD(hour,-4,(dateadd(second ,dateTimeOrigination, '1/1/1970'))) >= @StartDateTime
AND DATEADD(hour,-4,(dateadd(second ,dateTimeOrigination, '1/1/1970'))) <= @EndDateTime
order by datetimedisconnect
