how can I have activation code for my phone CP 8861?
eric.blot
Help
I want use my CP 8861, in sip communication système, but I can't use it, because  I haven't activation code, and the screen is locked.
How can I do to unlock the screen ?
Eric
13 Replies 13
tarun.gandhi923
Hello Eric,
Kindly reset the phone..
Menu -> Admin Settings -> Reset settings -> Reset device
BR
Tarun
Thank you Tarun,
I have made your Reset procedure, but the same screen appear again.
My problem is that I haven't activation code (serial of 16 numbers). Where can I find this code, to use my phone ?
or there is another solution to use my phone with a server SIP ?
cordialy
Eric
Hi Eric,
Can you please send the screen shot?
Tarun
Hi Tarun
On the other hand, I have tried to enter IP adress of my server sip, a username and his password, of a SIP user but, the phone doesn't recognize anithing.
Eric
Hi  E
Hi Hassan
Thanks for you answer, but I always have the same welcome screen
so, I remove the Ethernet cable, the phone is OFF
I press # Hold
I plug the ethernet câble
I try to wait the white screen or I try to wait Cisco screen  or I try to no wait
I release #
and I press 123456789#
and I don't have a menu to setup TFTP mode
Perhaps I make a mistake in your procedure ?
Do you have another solution ?
Best regards
Eric
Im not sure I am the right person.
Laura Winkeler
Engagement Specialist | Lifecycle Services
Federal & Commercial East
World Wide Technology
1 World Wide Way | St. Louis, MO 63146
Hi Eric,
Only Remove the Cable press # and hold connect the Cable and don't Remove
your hand # wait 3 sec then press 123456789#
BR
Hassan
On Fri, Feb 23, 2018 at 11:42 AM, Laura Winkeler <community@cisco.com>
Hi Hassan
I tried your procedure, but it doesn't work.
I always have the same screen, and I can't choose TFTP Option to communicate with MRA.
Please, do you have another solution ?
Eric
Hi Eric,
Good Day,
Let me check our system .....
Hassan
Looking for update.
Having the same issue.
from where get MRA address to set TFTP Option.
Thanks for your consideration.
check your ip phone is connected with Correct Vlan
awais.abrar
this is cause of the use of different firmware one is designed for the enterprise other one is third party call control (multiplateform firmware) below is the document might help if you want to migrate from or to enterprise firmware
https://www.cisco.com/c/dam/en/us/products/collateral/collaboration-endpoints/unified-ip-phone-7800-series/firmware-migration-master-guide.pdf
