I am using CUCM 10.5.1.10000-7 and am using ILS to propogate dial plans between two clusters. We use quite a few CTI route points but so I generally import them into the cluster with all the appropriate settings and line association settings. I need to be able to enable and set the various ILS settings line Advertise Globally via ILS. This can be done on phones and their line associations but not on CTI route points as far as I can figure. The same goes true with the Bulk Administration, you can updates lines of the phones for these setting but not CTI route points. Any trick or even obvious thing I am missing? Setting these manually is extremely time consuming.
