How can I keep English as the default GUI language for CUCM?
JIANDE ZHANG
Beginner
Beginner
After I installed locale package: cm-locale-zh_CN-ES-7.1.5.1300-1.cop.sgn. The administration GUI language changed to Chinese. But I want to keep English as the default languge. I guess there is a switch in somewhere to switch default language. It seems default language will be changed to the first locale language package.
Who knows how to change the default GUI language back to English? Thanks in advance.
5 Replies 5
Jaime Valencia
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
The language you get will be according to the language settings from your browser.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Hi, Javelenc
Thanks for your answer.
But I guess you misunderstand me.
I want to use English at this http://cucm ip address/ccmadmin.
Jaime Valencia
No, I got it right.
In the past there used to be a drop down menu for which language you wanted, not anymore.
The language you get completely depends on your browser language settings.
java
java
Henke Co
Beginner
Beginner
Did you solve the problem,I got the same one,please share with us. 3Q
Ok I happened to see this post.
You will have to change the prefer language setting of your browser.
Use Firefox as an example, go to Options -> Content -> Language, then click on the Choose button, and adjust the language preference accordingly.
Recognize Your Peers
