How can i set a password to make a call on Cisco phone with CME
zineb
Hello
My question is : How can i configure a required password to make a call on Cisco phone with CME
Best regards
8 Replies 8
silvervoip
FAC (Forced Authorization Code) - This is name of the feature you need to apply.
Do you want to enable it from Desk Phone to External calls?
//Please always rate helpful comments//
Hello
Thank you for your response
I want to enable this function internally
This will help me to have a personnel access and use  for each user
Is that possible ?
I think there is a misunderstanding. Which one exactly do you want?
1-) PIN code like on cell phones?
2-) PIN code to perform external calls (for example international)?
3-) Do you want to limit some people not to call a group of people in the company (example: senior managers should be called by everyone)?
4-) or you please tell exactly what you need?
I want to configure PIN code like on cell phones?
User can't make a call without his code or password
This is not possible. You need 3rd party application. If Cisco recently published a feature that I did not see, then yes.
But as far as I remember from my personal experience and comments of other members this is not possible.
For this, you need to build a logical structure so based on this you can setup hierarchy.
Please refer to URL:
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/manual/cmeadm/cmefac.html
What I'm asking is this: if a user wants to use his phone to call someone internally, it would be mandatory to enter his password or code to call him and I want this code to be unique, ie one code per user
That is not a function that exists in the system.
Response Signature
Hello
I try to implement FAC on my cme but it does not working
You will find below my configuration
gw-accounting aaa
aaa new-model
aaa authentication login default local
aaa authentication login h323 local
aaa authorization exec h323 local
aaa authorization network h323 local
aaa session-id common
voice lpcor enable
voice lpcor custom
group 11 LocalUser
group 12 AnalogPhone
voice lpcor policy LocalUser
service fac
accept LocalUser fac
accept AnalogPhone fac
voice lpcor policy AnalogPhone
service fac
application
package auth
param passwd-prompt flash:en_bacd_welcome.au
param passwd 54321
param user-prompt flash:en_bacd_enter_dest.au
param term-digit #
param abort-digit *
param max-digits 32
username 134 password 0 123
voice-port 0/0/0:15
lpcor incoming AnalogPhone
lpcor outgoing AnalogPhone
dial-peer voice 1 pots
destination-pattern 0[9734524].......
port 0/0/0:15
forward-digits 8
voice register pool 7
lpcor type local
lpcor incoming LocalUser
lpcor outgoing LocalUser
