How do I disable SIP-ALG in my router or firewall?
Dexter322
My company is moving to VOIP phones and we were asked to disable SIP-ALG. I ran the command and performed the test that the company wanted me to run. In the test results it's still showing the SIP-ALG is enabled. Has anyone ran into this issue? Below is the command I used .
config t
policy-map global_policy
class inspection_default
no inspect sip
end
Leo Laohoo
no ip nat service sip tcp port 5060
no ip nat service sip udp port 5060
That's how to disable ALG on Cisco routers.
Can you describe what would be possible impact if we execute these commands in our router in production?? Thank you.
M02@rt37
What is your Cisco router series?
Thanks.
Best Regards.
Ben
Best regards
MSD1001
how Do I disable sip alg for a range of ports on cisco C921-4P router ?
no ip nat service sip tcp port-range 6100 6200
% Invalid input detected at '^' marker.
Please advise
