How do I implement VoiceGateway redundancy and E1 Line redundancy
CN_donke.xu
Hello Friends
 I have two voice gateway,Both had the VWIC3-2MFT-T1/E1 card. And now we also have three E1 line. Who can tell me how do I implement equipment redundancy and Line redundancy ?How do I do on the gateway configuration?
Best Regards
Donkexu
2 Accepted Solutions
I was writing from my phone app so was difficult to explain in detail. Now I am back.
Create single RG with both H323 gateways assigned (GW01 & GW02). Use distribution algorithm as circular to load balance.
For VG1 which has two E1 lines, you can configure a trunk group and make you hunting algorithm as circular. Then use this huntgroup for your outgoing dialpeer.
Now regarding your DIDs, it depends on your telco. If your telco is extending the same range of DID to all lines then all your DIDs are available during failure of any line for inbound calls. However, if your have different blocks of DIDs locked to different lines, some of the DIDs won't be available depending on the failed line.
For outgoing calls, they will always work, however, the caller ID might be different depending on what your telco is excepting as caller ID
The configuration for trunk groups in PRI can be achieved as below.
controller E1 0/0/0
 pri-group timeslots 1-3,16
 trunk-group test timeslots 1-2
Also, if you have two dialpeers with same patterns and preference, they will load balance the calls randomly (by default). You can change this using dial-peer hunt command
10 Replies 10
Leonardo Santana
Whats your IP Telephony Solution? CUCM? CME?
Take a look on this dicussion i think this fits to your situation
https://supportforums.cisco.com/discussion/11688856/gateway-redundancy-e1
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
HI Leonardo Santana
I use CUCM,I just want to know What kinds of way can implement equipment redundancy and Line redundancy.Can i made my VG01 and VG02 in a Active Active Mode.How do I achieve the best use of E1 lines.
Best Regards
Donkexu
You can add your gateways to cucm using sip, h323 or mgcp. Then create two route lists, one for each gateway, and use circular selection. This will load balance calls across both E1
Yeah,I had finish h323 config and I had config RG01 and RG02 with Distribution Algorithm as Circular,
RL01 Selected Devices RG01 and RG02
RL02 Selected Devices RG02 and RG01
I know E1 has different DID so I don't know what need i pay attention to for my voice gateway config,If  primary VG01 is down ,All my DID is still available?
dial-peer voice 9 pots
 description PSTN-OUTGOING-LOCAL
 translation-profile outgoing To_Pstn_Local
 destination-pattern 9T
 port 0/0/0:15
 port 0/0/1:15
//Is It  feasible?
HI friend
  I think i had understand what you said,About DID I am clear now.
About VG
1.when i configure a trunk group ,it noted this error.
VG(config-voiceport)#trunk-group PSTN-Trunk-Group
 Error: Failed to add non-analog port to trunk group
  Configure in cas-custom mode or serial interface
  mode for T1/E1 digital ports and in BRI interface
2.Can i use two dial-peer to implement  Line redundancy?I have read the document,but I don't know whether my understanding is correct.
If the same preference is defined in multiple dial peers with the same destination pattern, a dial peer is selected randomly.
From Cisco Doc:http://www.cisco.com/c/en/us/td/docs/ios/12_2/voice/configuration/guide/fvvfax_c/vvfpeers.html
 description TO-PSTN
 translation-profile outgoing TO_PSTN
 port 0/0/0:15
dial-peer voice 10 pots
 description TO-PSTN
 port 0/0/1:15
Thanks&Best Regards
Donkexu
controller E1 0/0/0
Hi Friend
Thank you for your help,I have a idea now
Best Regards
Donkexu
Can you describe the topology?
Hi friend
 As the picture shows,I had two voice gateway and three E1 lines,Gateway use h323 to CUCM Cluster,IPphone use sip or sccp to CUCM,How can i implement equipment redundancy and Line redundancy,i want to made best use of my voice gateway and E1 lines.I want to know how do I config my voice gateway.
Best Regards
Donkexu
