02-08-2016 04:22 PM - edited 03-18-2019 11:48 AM
I have 8X versions of Call Manager, Unity Connection and Contact Center.
Can I last until the end of this calendar year or need to upgrade ASAP?
02-08-2016 04:40 PM
You can use it by year end, however you will not be entitled for TAC support once you reach the Last Date of Support as mentioned in the eos/eol documents which is Aug'17 for Ccx, Unity and July'17 for CUCM.
http://www.cisco.com/c/en/us/products/collateral/unified-communications/7800-series-media-convergence-servers/eos-eol-notice-c51-730843.html
http://www.cisco.com/c/en/us/products/collateral/unified-communications/unity-connection/eos-eol-notice-c51-731028.html
http://www.cisco.com/c/en/us/products/collateral/customer-collaboration/unified-contact-center-express/eos-eol-notice-c51-731138.html
You should upgrade the applications to the latest version prior eos date to get the continued support and better experience.
02-08-2016 04:59 PM
I'd consider the fact that those will no longer receive any maintenance releases anymore (since August last year), as a reason to upgrade now, before you face something that might make you upgrade to fix it, with no time to plan this properly.
