IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5619 Views
  • 14 replies
Guys,       I have cube which is connected to itsp and cucm 9.1. Both are on sip trunk and everything is working however i cannot hear audio for some international calls. Stream is dead and counter on ip phone increases which means that the call is c...
I have multiple Cisco 7961's and I can not get them to register on a Vodia PBX, below I have added the current config that I am trying to use. My problem is that I can use this config (with altered names, passwords and proxy) with a local Elastix box...
bringrose by Level 1
  • 484 Views
  • 3 replies
I have 7941 ephones and I need to move and give them a different room number, so I changed the name of the phones on the server and saved it, but when I called my phone extension the old name still shows appears as who called, but when I look at phon...
