How Many Meet-Me Session
jalston45
Hi we are running CCM 4.0 in a UM enviroment. We have a Meet-Me number set up and it will accomdate 20 users. My question is how many meet me numbers can you set up within a company with 4.0 Also where is the setting that allows you to extend the number of callers on a meet me call?
Thanks - James
thisisshanky
Level 11
Level 11
James,
I dont think there is a limitation on number of meetme patterns you can set. Regarding the number of callers per meetme call can be set using the following Service parameter. (Callmanager service)
Maximum MeetMe Conference Unicast: This parameter specifies the maximum number of participants that are allowed in a single Unicast Meet-Me conference. The value of this field depends on the capabilities of the software/hardware conference bridge; for example, a software conference bridge conferences up to 128 participants. When a conference is created, the system automatically reserves a minimum of three streams, so specifying a value less than three allows a maximum of three participants.
This is a required field.
Default: 4
Minimum: 1
Maximum: 128
Sankar
PS: please remember to rate posts!
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Thank you Sankar
Rob Huffman
Hi James,
There is no restriction on the number of MeetMe Number Patterns as far as I know. But of course you would need the appropriate Bridge resources as well asan increased number of PRI's etc.
To increase the Maximum number of MeetMe participants;
Go to:
Service Parameters Configuration >Clusterwide Parameters (Service)>Maximum MeetMe Conference
Here is some additional info;
Conference Bridge Configuration
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00801ecf8a.html
Adding a Meet-Me Number/Pattern
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00801ecf96.html#76011
Hope this helps!
Rob
**Edit: Sankar, you must slow down for me to keep up :) Remember my lack of typing skills!
Thanks Rob
