How to apply "media flow-around" voice/media loop
ivpere0032
Hi people, we have na issue with a crash on router gateway.
258  -rw-      227471   Aug 8 2016 14:07:40 +00:00  crashinfo_20160808-140739-UTC
 259  -rw-      258182  Aug 12 2016 18:48:42 +00:00  crashinfo_20160812-184843-UTC
According to https://bst.cloudapps.cisco.com/bugsearch/bug/CSCus45019/?referring_site=bugquickviewredir
how could we know which is the dial-peer in loop.
Ivan
5 Replies 5
Gregory Brunn
If this is a SIP CUBE config you can do it globally if you are indeed seeing this bug.
Voice service voip
sip
media flow-around
Hi Gregory, thanks for your help. It´s not a SIP CUBE, so we have to apply the command in the dial-peer on loop  right? Thanks !
No documentation states you can still do it globally
enable
conf t
voice service voip
media flow-around
http://www.cisco.com/c/en/us/td/docs/ios/voice/cube/configuration/guide/15_0/vb_15_0_Book/vb-gw-h323h323.html#wp1318898
Why don't you just upgrade you IOS code to the version that is not affected by the bug and rule it out?
We did the upgrade, but i will verify the information with the versions and let you know. Also we will try the command globally that you said..
Thanks ! you helped a lot.
Ivan
