12-05-2007 08:19 AM - edited 03-15-2019 07:36 AM
I am having some issues on how to work with authorization levels. I used the Forced Authorization Codes but i do not know how to associate them to a specific user in a scenario where only this user would be permited to make internacional calls for instance.
I already have it configured on the route pattern for internacional calls, now I can't associate it to this user?
What am I missing. Can someone please give me a light on how to solve this issue?
I am using CallManager 5 :)
Best Regards,
Ricardo Rolhas
Solved! Go to Solution.
12-05-2007 09:36 AM
You do not associate to a user , it is per route. The only way within CCM is to set up a route pattern for the user and assign a unique Partition to the Route and only assign this parttion to a CSS which is inturn assigned only to this user- messy
12-05-2007 09:36 AM
12-05-2007 09:59 AM
Thanks for your help. I was associating the partition to the directory number of the users device... not associating the CSS to the device itself :)
Best Regards,
Ricardo Rolhas
