How to block internacional calls in one dial number
carlostrapiello
I need to block an international calls (it begins by 00 in my country) only to one extension.
Can anybody say me how can I do it?.
19 Replies 19
I don't want to block all international calls for all phones in all offices only in one phone sited in one of the offices.
I repeat the scenario to you, maybe It would help you.
I have two types of partitions in my net, one for all internal calls and another type with twelve partitions for each office to do outgoing calls. I have a calling search spaces in each office associated to the partitions that I said before and route pattern for international calls permiting these for all the net.
OK.
One extension in one of the offices (lets say, the lobby phone) must be blocked to international calls, and must just be permitted to internal and national calls. Am i right?
Let me see if i can find some solution that helps...
More or less.
I want to block international calls only in one phone and permit all types of calls including internationals in all the rest of the phones in my net.
sohaildxbfze
lets finish this thread,
Scenario: To block 01 phone in ur site to dial 00!
Solution: Make Sure,
1. ur all international OR 00! Route patterns are contained in ONLY INTERNATIONAL PARTITION.
2. INTERNATIONAL PARTITION MUST be included ONLY in CSS INTERNATIONAL!!!
3.APPLY only NATIONAL OR LOCAL PARTITION ON THAT EXTENSION (DID) OR PHONE ITSELF. no that extension/phone can reach only NATIONAL OR LOCAL devices/extensions(DIDs)/route patterns
4. APPLY only CSS NATIONAL OR LOCAL [contaning all except INTERNATIONAL PARTITION]
this is the only solution using css/partition to block/restrict a device/extension(DID
Be calm.
There wolud be a good solution if the scenario will the same as my net but this is not true.
I repeat that my partiotns are not distributed by national or international calls. Read my lastest post to understand partitions are distributed in my net.
I don't say that solution must be with css or partition. Do you know another best solution?.
