How to Call Forward to Mobile Phone after 5 rings with Cisco IP Phone 7945
Brierforest1
How do I set my IP Phone 7945 to forward my calls to my mobile phone after 5 rings?
Terry Cheema
Easy way is to configure call fwd no answer to your mobile phone, along with No answer duration in seconds to a value you require. This is under line settings.
Other way is if you have a SNR setup then you can tune the Delay Before Ringing Timer under the Remote destination. It will wait for the time you have configured before the calls are extended to your mobile phone.
-Terry
Please rate all helpful posts
Terry Cheema
-Terry
Thank you for such a quick reply!
Not a prob mate, glad that helped!
-Terry
