UCM 10.5 upgrade to restricted
jgracecco
Is there still not a way to switch or upgrade UCM from unrestricted to Restricted.  I want to take my UCM 9.1 up to 10.5 s2.  but I need to switch it back to restricted.
Jaime Valencia
No, there is no way, your option is BAT.
java
if this helps, please rate
OK  so I have a 9.1 version unrestricted, and I have a 10.x restricted version up. I guess the best way is to get both server on the same version and then start bating the phones over.
+5 to Jaime.
Yes that appears to be the best way around. BAT may work between different versions but you will need to play around with that, its a bit of a hassle.
If you build the systems with same versions and use BAT and then upgrade to the desired version will be a better approach.
-Terry
Please rate all helpful posts.
